Started cleaning the body up. Sanding down all of the joining lines and making the area around the fuel filler look better.
I marked some spots here that I will address later, but both rear quarters will need to be modified quite a bit. I'll get to that in a moment...
I'm happy with how the fuel door turned out. It will be nice to be able to fill the car up at a gas station without getting weird looks. (Picture someone elbow deep into their wheel well fishing for the fuel cap.)
I started widening the panel gap here. I realize the car probably won't have consistent panel gaps all around, but I'll attempt to get them close enough. This area sits right on top of the sill, so I've been sliding sand paper between them to try and open it up a bit.
This is my solution to my wheel well liners. The original wheel liners in the rear of the car attached on the forward, top and rear. The rear bracket no longer exists for the rear so the back side of the wheel liner was just hanging. I made a small aluminum bracket and mounted a bolt to it. I think it will work pretty well
Ta da! Exciting isn't it?
Wheel liners installed. Looks like I have a tiny bit of trimming to do on it yet, but it's super close being done.
The last mechanical bits I'm messing with is the trunk. If I get that set I can put a lock on it and focus on the weather seal and just cleaning the body up! So exciting...maybe it's worth a vacation week to hammer through. I'd love to see paint on this car. Originally was thinking a blue/green, but I came across a single stage "isle of man green" from Tamco. Very tempting. It would be a cool nod to both BMW (because isle of man green is a BMW color) and British racing green (because get it? it's green.).
Anyway, where was I? Right. The trunk. It's a battle.
Here is a problem. The rear end is now fixed in place, but look at the panel gaps. There isn't one between the original red panel and the quarter panel. I can't just shave the quarter panel because the panel gap will look super weird as it transitions to the trunk gap. Another option is to cut the rear quarter and shift the entire panel gap which would require widening the trunk. Third option is to maybe put a small 2" rubber piece there to cover it up on both sides. Forth option is to just live with it. The other side of the car has a decent gap, so it is not symmetrical (this bothers me). I haven't decided how I'm going to do this.
Didn't I already post this picture? Yes, but now we are looking at something else. Look at the trunk. It sits flush with the rear quarter panel up until the body curves down, then the trunk sits proud of the body. I think I'll have to build the quarter panels up to match the trunk here. The other side is very similar. I can't do any of this until I finish getting the trunk to sit right though...
I'm also debating on shaving the rear lip to make the body and trunk flush together. This would require building up the body from the back so I have enough material to shave off. It would be a lot of work and would be shaving off a LOT of material. Roughly 2-3cm!
It's so nice out I want to be driving this. Don't rush...don't rush.
I also want to thank my dad for giving me sanding blocks that I can connect to a vacuum. Holy cow it cuts down on the dust.
