Busy weekend for me on the zed as the wife was away on a training course.
After a nice drive on saturday morning i cracked on with a job i've been meaning to do for a while.
i had noticed that i had a small oil weep
and it was the cam cover gasket that was playing up.
So a quick order to Sopers Lincoln and we had all the bits.
The process is so easy but takes about 2 hours:
all you need is
10mm socket
8mm socket
flat blade screwdriver
torque wrench it you are being fussy (i am)
engine cover off, screwdriver to remove the four blanks and then 10mm nut x 2 and 10mm bolt x2
leaves you with access to the coils
each held on by 2 x 10mm bolts and a clip for the connector, clip slides up and then out, whole wiring assembly can be removed for access very easily (circular connector and some plastic clips)
there are 3 x 8mm earth straps too
notice im lining everything up as it came out, as everything was working before i dont want to swap the coils etc
leaves you with this, they you crack on with the 15 x 10mm nuts that hold the cover on. They all have a metal wsher and a rubber bung attached to them. be careful not to drop any. the rears are harder to get at but a little wobbly extension on the socket is all you need.
small rubber mallet taps to the cover and some wiggling and it'll come off, it will be tight as the old gaskets would have bonded to the head a little.
shiny bits.
as per any gasket installation, clean up the mounting surface and scrub an sections that look rough.
BMW advise that you run some sealent at the front in both corners and the half moons at the back.
refit as per above
then i went on to dye the leather seats as they were in a poor condition when i bought the car
used this kit
process is:
degrease
intensive clean
gentle clean
condition
gentle clean
degrease
dye
dye
dye
dye
dye
some before shots
used a small sponge to cover the leather, let it dry and then go again, did about 5 coats.
after
its a little patchy still so i might do another two coats
