i concur, no chanceThere is no chance of you getting a slim subwoofer under the seats, even with a seat raiser kit. I had to fit mine behind the seat.
behind the seats would be the only way
Ive got the standard harmon kardon sub in mine and with upgraded front speakers it sounds very good (for a convertible), might be worth retrofitting that
I would but I don't want to go through the hassle of replacing the loom, finding space for amp & bracket and gutting the car. I drive it less than 5k km a year and, during that time, I could do with the exhaust note and some background music.Ive got the standard harmon kardon sub in mine and with upgraded front speakers it sounds very good (for a convertible), might be worth retrofitting that
So after fitting the LED bulbs to the rear lights and side repeaters i was presented with hyperflashing as the relay was thrown out of sync with the lower draw from the LEDs.
3 options here;
fit resistors to all the led bulbs to 'trick' the relay or mod the relay itself.
3rd option is to fit an off the shelf LED flasher but that requires running little pigtail wires as noone makes a 7pin relay.
the resistors are easy and cheap but always feel like a bodge. so i decided to mod the relay follwing a guide on bimmerfest.
what you need:
2 x small screwdrivers to open the relay
soldering iron + tiny amount of solder
very small drill bit (dremel etc)
1 x schottkey diode (i got mine from RS 781-5616)
Go find your fuse box and the relay
this is the original 7 pin BMW relay
wedge open the two sides with some very small screwdivers and then the board pops out
here are the guts
the bit that controls the flashing frequency is the 'M'shaped piece of metal (acts as a resistor)
unsolder the 'M'
next the holes need to be enlarged to get the diode through
pass the diode through and solder the pins
snip the tails off
completed. (note the positon of the band on the diode)
clip the relay back into the holder and pop it back in the car
start your car and test
et voila, no more hyperflashing and the ability to run LEDs all over the car
Great to hear that you had success with this. i'm actually making a few up to sell for other people who might not be confident enough to solder their own.I followed your instructions to upgrade the relay and it works beautifully, so thank you very much for the information. I also think the fact that you can run either traditional bulbs or Led bulbs or both at the same time from the modified relay is very good. Very pleased with this upgrade
I might take the instructions down then so people can buy the ones ive made@5harp3y This is a brilliant thread, so much detailed info Just ordered some diodes to do my flasher unit (as your instructions ) as my indicators are the only ones not LED.
ive got 4 left £22 posted anywhere in the UKIf I'd know you have made some I would have got one from you, have you got any and how much?
I didn't think about lacquering but will nowVery nice Z, I like a lot of the little subtle changes you've done, especially the illuminated gearknob
Is it an E46 only part?
Also regarding sanding your brake light down, I'd highly recommend lacquering it to prolong the finish. I'm sure you've guessed but you can also do the same on the main rear light units
Glad to see they fitted mate, looking good.T
So i picked up some rear facelift trims with speakers from Andy and set about fitting them.
Next weekend i'll also be sound deadening to boot floor as ran put of time this weekend.
Yeah I'll send you one as I got a few, you can buy me a twix next time we meetGlad to see they fitted mate, looking good.
If you've got any of that metal strip for an induction kit going spare? I'll be playing with my new toy soon, I've loads of old open filters around, will test a few out over the next couple of months.
Like I said last week, those strut caps look the business
Cheers
