Today started with removing the jacking point rubber mounts. One of the screws was a bit stubborn, but realised I could spray release fluid through a hole in the sill to get to the other end of it......a useful trick which I will repeat when I get to the stage of removing the 4 ‘screws of doom’ that hold the the beam plate.
First thing roof down......very slow and needed help......something for another day!!!
Removal of the interior went pretty much went as I though, having done this on the other car.
Getting the radio out was a struggle , even with the correct tools.
Managed to remove the gear knob without smashing it into my face.....once bitten...
Had a swearing match with it trying to remove the two roll bars, until I remembered there is a third screw located behind a cover plate in the storage box.
Other than finding additional cables, and electronic stuff that I didnt have on the 1.9 , and wrong fasteners used, it was just undoing loads of screws and putting all the bits out of the way, and moving on to the next bit.
Sum total of finds .......a dead AA battery and 55p in change.
Found out why the seat wouldn’t go up and down.....the silver looking bit is not connected to anything
and is jammed against the frame.
Carpet was soaking underneath....and so is the front one
The two seat belt guides are broken so will have to be replaced, so if I have to take the covers off.....might as well retrofit heated seats as I did in the other car....just need the two switches , a relay and the heat pads....
I was defeated in the end as I couldn’t work out how to get the front carpet out. I removed all the panels etc, but there is a big plastic stud that looks like it has a cross in the middle for a screwdriver ( but damaged !!!) and I cant see how to get the carpet away from the accelerator pedal ????
I dont want to cut it but does anyone know how it come out ?
Other than that it was a good five hours
Other than wet, the floor looks in good condition. A few surface rust spots but they are easily treated .
Be nice to get the front carpet out this week, ( as cant work on the car next week) , and it can then just sit and dry out over the week.
