5harp3y
Have you tried removing the rear spring pads. I believe it’s something like 1.6 ratio so taking out a 10mm pad gives 16mm drop.
How did it drive with that set up?
Didn't drive it as it looked so bad.
I was tempted to take the pads out but to keep a bit of nvh control
inkey$
Kent & Suffolk
'01 2.2i M54
Just read through this entire thread. Great work and very inspirational, Sharp3y.
5harp3y
Another small update.
@spurs fan in a coupe kindly sold me some new boot carpets so I could remove my hump.
Small issue that I had to remove the HK amp as it doesn’t fit behind the carpet nicely. I’ll do some research to see what I can do as I now only have front speakers.
Anyone else done this with the HK setup?
Loads more boot space though so I’m overall very happy
Got myself a genuine bmw first aid kit for £5 to finish off the boot for now.
Next job is a big front end overhaul.
I’ve got brand new wishbones, steering rack ends, gaiters to go on
Along with 300mm front brakes from a e46
All that’s needed for the brakes is the carriers from the donor car which I picked up for £20
They are currently soaking in a bath of citric acid to remove the rust
Also ordered some front HEL braided hoses and will be buying some brand new (refurbed callipers)
andyglym
Be interested to hear the outcome, I did the same but ended up with no speakers so had to reverse back.
5harp3y
Looks like the previous owner has bypassed the amp and wired the front speakers up to the Headunit. I'm tempted to do the same for the whole lot or see if I can come up with something
Can't seem to see a spot where the amp can relocate as the wires are so short
Antm72
South Yorkshire
Is your amp in the hump ? mine is not it was just empty it mounted on the drivers side rear on the arch behind the carpet.
Dino D
Kent
2.8 Manual
Mine was I'm the hump above the cd changer
Mine used to be there too.
I just wired the speakers separately as was changing them all anyway.
I have 2 amps now - a mono in the boot for the sun (amp in the hump) and an Alpine in-line amp for the speakers behind the glove box area that powers the 4 in car speakers.
Dino D
Kent
2.8 Manual
That’s a neat spot...mmmm time to get rid of my hump too it seems!
Antm72
South Yorkshire
As said mines rear drivers side arch mounted.
And under neath a bracket with the H.K amp bolted to it.
:thumbsup:
  • Like
Reactions: Lee
5harp3y
Wow, completely different set up to mine.
My wiring is on the other side of the car
5harp3y
Reverted back to the humped boot as cannot relocate the amp.
Also stripped the brake carriers using citric acid. It’s done a great job , taking off all but the most stubborn rust. It also softened up some old paint but didn’t remove it so that wasn’t removed manually.
The beginning
After a week in the acid , super clean
First coat of bilt hamber electrox ( galvanising spray)
They will be getting a coat of brake paint after this.
But not sure on which colour. Thinking silver
Jjim
Mansfield
1.9 Roadster
Looks like they came up well after a soak
5harp3y
they have come up much nicer than i expected, going to paint them with some caliper paint next and then fit them up at the weekend.
just been amassing parts
Mario
Hello @5harp3y
I am looking to rust proof the wings from the inside.backside while they are off, is Dynax S50 the best product? I have seen people using waxoil and other products like stone guard spray etc... thanks.
