Rebody Z3 Donor - Options and other rebody questions
Dxbolton
New Forest
2.8 auto
Yes. You need to pull that rubber strip from the top of the door. The new door skin slides down into the gap where the rubber used to be.
I seem to remember a picture on @Dxbolton 's build thread. He's also stuck the rubber back on top of the new door skin. But watertight? The original door wasn't watertight anyway so don't try to make the new one watertight. Water will get down inside the door. You need to make sure your memrane behind the door card is good.
The sliding window is watertight but I did get the occasional drop by the quarter window. I’ll just make a tighter fit when it’s back from the paint shop.
I refixed the seal in place with Tigerseal to the top edge of the skin
