We dropped the rear suspension over the weekend. And dismantled the roof seals.
The shocks showed no rebound so confirmed as needing replacement. A reminder that even a car like this which was lovingly maintained by it's previous owner can conceal issues. The springs, trailing arms, fuel tank straps & axle carrier all have some surface corrosion which will get an MOT advisory so they will be cleaned up and treated.
The roof has been pulled back and the plastic sealing strip also removed - chassis>butyl>sealing strip>butyl>roof. It's a messy job cleaning off the old butyl then it will be relatively easy putting it back. There's also a neoprene foam seal that sits around the butyl and that has to to be replaced too.
The A-pillar seals will need a rubber patch over them to make fully water-proof. I've put silicone in currently and it's doing a job but I think it will be too susceptible to moving and splitting.
The front shocks will be removed and tested and we're expecting to replace them too.
I've noticed the diff is leaking from the drain plug hole so we'll change the fluid and put new crush washers on both plugs.
And my reversible wiring loom modification to add new horns is coming along. I'll write this up separately as it gives a brand new pair of OEM horns for around £35. It obsoletes the need to look around for secondhand ones which are mostly all knackered now.
