Having pulled the loom through the bulkhead we were now keen to run it along its main routes and to start securing it where it made sense to. There's not a lot of room to move in the cabin and we were concerned about leaving it laying around where it may have got trodden on.
There are also some key initial locating/connection points that give a good indication of how to tension the loom and exactly how it should lay before clipping.
We started off with the positive distribution panel that tucks up under the passenger dash. This comes complete and pre-assembled on the loom.
Then we ran the driver side leg to the boot space. There's not a lot on that one. It ends in the smaller of the 2 positive connections and the long green fuse unit that sits near the battery. It also has the accelerometer sensors and seat plug. But the important thing is the loom has 2 built in locating studs, bound to the cabling, that can only go in one place (under the seat). That's the sort of thing we were looking to pick off to locate the loom. It also has the fuel pump and an earth on a branch so that was our first connection we re-made.
Then we ran the passenger side leg to the boot for the same reasons.
What I then wanted to do was to bite the bullet on 1 of the 2 areas I knew would be most difficult. The driver instrumentation and the DME (engine management partition) on the left rear as you look into the engine bay from the front. It had to be the DME first as that leg needs to pass back out into the engine bay and it was easier to do that before the instrumentation was connected.
There was a lot of stuff to get through a small hole!
Making a start.
And the final squeeze. I love this. We couldn't work out why the DSC (brake) module plug was heavily cling-filmed wrapped when we first unboxed the loom. Well the reason is it's the single most difficult item to pass through any hole as it goes last and through the tightest gap. 10 out of 10 to BMW for these little things that have helped.
A bit more tugging and routing and the leg was sitting nicely back where it belongs.
Now it all has to be plumbed back into this stripped out partition. The cabling/boards in the photo are part of the engine loom which is a separate assembly. The engine side of the engine loom has very few connections. The DME side has a lot more! And these seat inter-mixed in the partition with the main car loom leg.
First the 2 connectors had to go back on the DSC sensors. The 1st one was difficult hiding as it was under the brake pipes out of reach. The 2nd at the back was almost impossible and I ended up loosening the DSC assembly to create a little wriggle room. It took about 75 minutes to get the 2 connectors on, the vast majority of it the 2nd one.
The neighbour returned just as I had completed it. She asked how it was going and I said it was a good job she hadn't have arrived 5 mins earlier because the air would have been blue! I'm so lucky my Parents' neighbours are so understanding with all the Z3s and work that goes on!
Here's the start of the plumbing in of the main loom components.
Plugging everything back in took about an hour. And I was thankful to have another car sat next to this one for comparison. Photo of the completed installation next time.
This leg also has some wheel arch connections (eg the wheel speed sensor) but I'll worry about all these connectors probably as the last task.
