toolkit
Big Slippy
Lanark, Scotland
Z3M roadster
Hi,
Should there be a jack in the boot, or not as there is no spare wheel?
thanks
BS
board
Staff member
Lincolnshire
M Roadster
adds too much weight so they chucked it on the M's ;)
swamper
Bacup
M
if it gets a puncture....just walk away and leave it...its broke!
Big Slippy
Lanark, Scotland
Z3M roadster
It's me thats 'flat broke'
Note to self - stop buyin stuff [-x
thanks for info :-bd
HornelZ3M
Raglan. South Wales
Z3M Roadster
Surely theres a jack to take the flat tyre off or have i had too much to drink /:)
board
Staff member
Lincolnshire
M Roadster
Nope no jack at all. I guess the thinking is that you have got to the place that does the new tyre/repair so they do it by that point. You do get a couple of spanners and a tow hook which is handy if you should get stuck in a gravel trap, or in mud on a field which is when i have used it :D
HornelZ3M
Raglan. South Wales
Z3M Roadster
I think you are wrong there, i could go to my m now and photograph the tool kit and there is a jack, otherwise i wouldnt have jacking points ;)
Snoops
Red Rose Country
Surely there's a jack so you can change a tyre yourself. Would have thought tool kit would be standard across range.
Snoops ont'apatalk
board
Staff member
Lincolnshire
M Roadster
Sorry was on the S10 forum working out how to change the diff oil :D
I can't actually photograph, mine as you know :p
There is a moulding for it in the boot but they weren't supplied with the cars so it's quite likely someone put one in yours afterwards ;)
What's the point of taking the wheel off at the side of the road if you have nothing else to put on? :D
Snoops
Red Rose Country
Why do you have to be at the side of the road with a flat... you might want to change a wheel in your garage.
Snoops ont'apatalk
HornelZ3M
Raglan. South Wales
Z3M Roadster
Well good point but what you are saying is if you wanted to perhaps change your brake pads then it not possible to jack the car up. we will have a poll who has a jack and who hasnt...... Hornel z3m 1
board
Staff member
Lincolnshire
M Roadster
you're already 2 - 1 down Hornel from the start of this thread :D :ymbringiton:
Excuse me Sir, one does not change ones own brake pads on an M, one takes it to the BMW trained technicians and they do it for you.
I remember reading all the press about not having the spare. It upset the 50:50 weight distribution and they calculated how many times you actually got a flat and so went with the inflation kit.
Snoops - If you're inclined to take the tyre off in your garage then i think BMW assumed you would have the jack already :D
Is there anything to undo the wheel nuts even, i don't remember if there is?
Aren't the jacking points used by the lifts in the service bays? ;)
board
Staff member
Lincolnshire
M Roadster
HornelZ3M said:
Come on keep up for gods sake
Some of us are still working at 18:40 on a Friday night :D
Big Slippy
Lanark, Scotland
Z3M roadster
Lovin this...
Just looked in M3.........no jack.!
Z has a wheel brace though. reason for asking was a plastic clip and nut with nothing to hold lying in the kit area?
BS
board
Staff member
Lincolnshire
M Roadster
AND we have a party here tonight that i need to help prepare for, i would invite you if you could make it in time :D
board
Staff member
Lincolnshire
M Roadster
C'mon Hornel, that's 3 to 1 now - you're move
board
Staff member
Lincolnshire
M Roadster
Big Slippy said:
Lovin this...
BS
I think the plastic mould in the boot is fairly standard across the range so has the space for a jack but never a jack supplied as standard :D
Still waiting for Hornel - has he gone to sleep now? :D
