The OEM Boot Rack discussion
hard top
Dutch Zeds
Netherlands
Perhaps someone could actually ask the manufacturer
Mike, the manufacturer manufactured the boot rack for the OEM BMW suitcase (which I have) and if you want to use the said suitcase, that is the way you have to attache/mount the boot/trunk rack on your boot/trunk to be able to use said suitcase the way the manufacturer intended.
On the other hand, if you do not have said suitcase, it does not matter one iota which way you attache/mount the boot/trunk rack if you are only transporting sheep and pumpkins.......:whistle:
Ashbandicoot
Passed Away, July 27 2015
Deceased
Rugby, Warwickshire
Why would anyone want to open a suitcase while it is attached to the rack? I'd keep my sarnies in the door pocket or in the missus's handbag
Because the case locks itself to the rack, if fitted back to front, you would need to detach from the side or lean over the case
Ash
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
As a non boot rack owner I have following comments:
1) As I know the Germans and their care for safety , I accept the position with the lip to the front: in case of a strong impact (accident, not just a sudden brake!), the suitcase will blow the heads of the passengers! In case they wear helmets, anyway will broke their necks!
2) When you range the suitcase on the boot rack, if the lips is oriented to the back, will protect the suitcase from slipping and damage the paint while you try to attach the suitcase to the boot rack!
So I'm a fifty- fifty supporter........:)
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
As so many owners have hoops installed I argue that the case taking off a head would not occur in cars so equipped. All others use at your dis creation and take your chances. This only applies to cars with suitcases not those with sheep! JIM
From another non rack owner, I would say as long as the suitcase is securely fixed to the rack it won't come off whichever way the rack is fixed to the car.:)
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Straight from the BMW catologue, case closed ( see what idid there)
.... also, how many of us have our heads standing proud of the headrests?
Z
zedonist
Guest
Can I point out that a sheep would cause more damage than the suitcase, hooves and horns and all that flailing about
Depends how tightly she was tied on...:)
I think that's Frankie's sheep suit.
Actually you'd have a job tying him or her onto a rack=))
