Nostradamus, thy name is meI'm not even going to attempt to remove the thermostat until the fan and shroud are out though, I am terrified enough of sheering a bolt, let alone trying to extract them with very limited space.
I knew it was coming, but it still felt like I'd been kick in the balls. The lower two bolts from the thermostat sheared as soon as I laid eyes on them
This was on Wednesday after the viscous coupling tool had arrived, which at least gave me a couple of days to research and source various things to try and get them out. I started with some stud extractor sockets (I didn't even bother trying the drill-chuck or cam style ones since I knew there would not be the clearance around the stud required, as it turned out there wasn't enough clearance for the socket style either. The other thing was a freeze spray but that took a couple of days to come. In the meantime, I shoved a load more blue roll around the bolts and doused them in penetrant and topped it up a couple of times a day.
By Saturday I had everything I needed, hopefully, and got to work heating the area with the heat gun, then spraying the stud with freeze spray, then hitting it with a hammer, then going at it with vice grips. The only vice grips I had that were small enough for the left one weren't strong enough and the two arms of the vice grip itself were twisting apart, if that makes sense. Next up, I hammered a 5mm socket onto the stud, cranked it and it came out!! Repeated the process for the other stud with another 5mm socket and that one came out too!
What a relief. Although I am now down 5 sockets - 3x 10mm sockets with various bolts and bolt heads jammed in them, and 2x 5mm sockets with the two studs wedged in
With those studs out of the way, I gave the front face of the engine a good scrub - I think/hope that it was just because of the PAS leak, but everything from that level and lower was caked in an oily sludge. Engine bay cleaner, a wire brush and more blue roll had it looking better wherever I could reach.
Then it was water pump time, to my amazement (and relief, since I had no more sacrificial 5mm sockets to hand) the bolts all came out with no fuss at all. The pump itself was another story though. I pulled it - no. I tapped it with a rubber mallet - no, I tapped it with a lump hammer - no. I read on Pelican Parts there are two M6 threaded holes top and bottom that can be used to draw the pump out - both tabs around these holes broke almost instantly. I tapped it harder with the hammer - still no I tried to be creative with some scrap metal I had, but 5mm hardened steel was bending and the pump hadn't budged. I decided to quit while I was ahead and leave the pump for now - hoping to god I hadn't killed it by trying to remove it! lol. It still span freely and didn't make any noises.
I lightly greased the bolts for the pump and thermostat and I lubed the thermostat seal with a dab coolant and fitted them up, plus the replacement rad hoses.
While I had good access, I cleaned up the PAS reservoir and hoses, then replaced those awful BMW hose clamps with new jubilee clips. I'll check on it again in a few weeks and if it's still leaking look to replace the hoses and reservoir too. I bought a replacement reservoir & hose kit, but despite claiming to be compatible with the Z3, the hoses that came are clearly not the right ones
Next up was this beauty, which I ummed and ahhed about for 20 minutes before tackling. On the diagram the lower one of the cylinder head end was totally perished and being held together (barely) with duct tape, which I 'topped up' before the MOT last year in the hope of curing the emissions, however I hadn't really looked at the other cylinder head end, which to me looked to be around the same area of the engine... however with the part in front of me and looking at the engine I realise it is about a foot deep around the back of the engine with no access besides a line of sight from the drivers side, and just accessible from the passenger side, but with no line of sight and reaching shoulder-deep under the intake manifold.
I really wasn't sure I should have started this, but I threw caution to the wind and jumped in anyway, with a bit of assistance from Mrs B on the drivers side who was in charge of navigating my hands and loosening and tightening jubilee clips with a long screwdriver. In the end it wasn't bad at all. I spent longer messing about trying to move the wiring box (what a faff that thing is!!), but it probably only took 10 mins to replace the hose section.
This was what the inside of the vac line looked like I think this was causing my lumpy idle. It never cut-out on me, but it did have me worried on a few occasions when waiting at junctions
With everything refitted and the cooling system filled, I started Tandy up to run it up to the temperature and follow the coolant bleeding process. I was amazed to see;
- It started
- No nasty noises
- No gushing coolant
Saturday's haul of replaced parts:
Sunday morning, no leaks on the cardboard so I refitted the splash guard, put the wheels back on and took it for a drive. I was out for about 30 minutes and the temp gauge was perfect. Also the heat from the blowers!! It was warm before, but only now do I realise it clearly wasn't as warm as it should have been! That will be nice now on cooler days.
I was going to tackle to rear beam bushes on Sunday, I have bought some threaded bar and a section of 3" capped pipe to follow a home-brew subframe bush removal tool. However despite being able to loosen the 22mm nut - which I was sure would have been the main blocker - when I looked at the mangled bolts holding the bracket to the chassis, I quickly changed my mind. I'm hoping to take the Z3 on holiday in a couple of weeks, and this has all the hallmarks of being a lengthy endeavor.
Instead I cleaned up and painted the rear disc hubs and I have removed the spare wheel cage hinge, however I cannot undo the 'wire', so it is unceremoniously hanging under the car at the moment while I have sanded down the corrosion and been painting it black. I taped a dust sheet over the back of the car to protect against paint & overspray.
Pretty productive weekend all in all, and glorious weather for being out both days working on the car. I have noticed one of the rear ARB bush brackets has come undone, so I've got floflex polybushes to fit at the same time as I re-seat that bracket, but apart from that I'm done now until after the holiday - providing Mrs B can pack lightly enough for us to fit it all in the Z3!
