?you need to censor this chap before it gets out of hand.
There will be a few pics of course, but should sit the same as Lees coupe as we both have the same suspension before and after.I'll be interested to see how it sits with those fitted Gaz.
No specific link or seller, just search on ebay and you will find several German sellers. Not sure what prices the ///M ones would be though.Can you post the link of the supplier Gaz, be interested in the price of a set for mine.
Why put it on in the first place if it causes restrictions? Does it cause problems elsewhere with removing it?Clutch delay valve removal!
All I can say is if you've considered this, then stop considering and get it done. Totally changes the feel of the clutch. No longer feels like it's slipping, and I don't get any judder in first any more. It's a 20 minute job, and can be done with the car jacked on it's side (jack and axle stand that is).
First time for Sasha to enter #ZedShed (tm). Tilt...
This is the offending chap, or rather chaps as we removed the one from Lees Coupe at the same time.
This close up shows how much the pipe is restricted.
Shown in place with the hose clamped before removal. Once removed the clutch line screws straight back on again.
Totally agree, and best part it costs you nothing to remove it! Free mods are the best!Good job boys, it's amazing the difference this small mod makes.
It's to make gear changes smoother, but in fact seems to add a little bit of slip to the clutch as the plates don't mate as quick as without it. If you are incompetent at changing gears it's actually helpful . If you have the ability to change gear without kangerooing or slipping the clutch it's essentially in the way!Why put it on in the first place if it causes restrictions? Does it cause problems elsewhere with removing it?
Hopefully in the next week or, didn't have enough time today!So have you managed to get your springs fitted today Gaz, we will need pictures to see how sasha looks with them on.
