Its not a zed but I need some advise regarding my fiances R56 Mini First. It decided to start leaking coolant on Tuesday and I had a quick look and it seems the water pump has gone. Called the AA who towed it to the garage. It's not been running right for a while, it judders a bit in most gears at low revs. It was showing misfire codes and changing the spark plugs made the problem go away for about 6 months. Anyway its always had a small oil leak and she decides not to keep on top of filing it up and has been driving it round with not a lot in. I did an oil change and service last week and it did seem to be running a bit better. She told the garage it was making some strange noises even though I didn't think it was to bad. They have called today to say it needs a replacement engine. They didn't bother looking at the water leak, left it idling for a few minutes and said it sounded noisy. They also said that the oil I drained last week would be full of sludge and swarf (it wasn't, just dirty) and that the bottom end had completely gone. I know running an engine low on oil isn't the greatest idea but I can't believe the engine would run as it did if it was that damaged.
A replacement engine is going to cost a fortune. I spoke to the garage about the car being a Mini First and he probably has next to no chance finding one of them engines, yet he says can fit an engine with the same code and it will be fine. By this he means one from a Mini One which are not detuned like the First, which will cause a load of hassle with insurance etc.
Do we take the chance and just have the water pump done in the hope it drives how it did before or fit a replacement engine like they suggest? The car is only worth about 3K now and a replacement engine is going to probably cost at least half that. At least if its running it can be sold on for a lot more than something not running which supposedly needs a replacement engine? It's not helping that there is some finance left to pay on it.
Sorry for the long post!
