Bulb has already been taken out,. \never used it in the dark.
Charger is now saying fully charged, will see in the morning.
Just bought a new, beefy battery for my new Z3 as it would go flat after a week or so despite looking suspiciously new.Most cars will sink some current out of the battery all the time. Usually it's fine for a couple of weeks, but after that it is sufficient to discharge the battery, especially if the battery is old and/or it gets cold overnight. That slow discharge can also build up salts on one of the plates. This also can impact it's useful life. Charging it reverses this process.
Don't know the capacity of the Zeds battery but assume is 75Ahrs. Big though they are it's a finite capacity. I'd expect most cars to take 50mA or more just doing their alarm duty and other electronics that are permanantly powered (door locks, clocks etc). You should get 6 weeks potentially. That's in perfect conditions. 3 weeks is all I would expect tops to be honest - anything more is upside.
Anybody done a current check on an car?
Sounds interesting. What, pray, is the Loom of Doom. Presumable pronounced with Gandalf accent?Have you checked the loom of doom? Mirror not adjusting also sounds suspicious. Cigarette lighter might be worth checking too.
Search loom of doom on here and you will find advice. It’s the wiring loom that goes to the boot lid. Common place for wires to break and cause a short.Sounds interesting. What, pray, is the Loom of Doom. Presumable pronounced with Gandalf accent?
Exactly what mine was took the bulb out never had the issue sinceThe light in the boot has been known to stay on when closed. Easiest way to check is to put a camera phone recording video in the boot, and close it.
I had that with the passenger seat. I'm 6ft and not often the passenger. But I'd rolled the seat all the way back. Next morning totally dead battery. I thought it was duff so bought a new one. Size of the spark when connecting up the new battery told me there was a big drain.When an electric motor moves something (seats, mirrors, windows) when the end of the travel is reached, you'd expect the power to be cut. Sometimes it doesn't so the trick is to get the item to the end of its travel and then just tweak it back in the opposite direction. Then when you release the switch, you know that the power has been cut successfully.
My drivers seat did that once- about a 10A draw though.
