DIY frustrations...
Dino D
Kent
2.8 Manual
Don't know wheather to cry or laugh.
Sorry to hear that certain aspects of the DIY work didn't go to plan. Learn from errors and try not to repeat them in the future.
On a old car, I was charging out a seized caliper. Could I disconnect the damn brake line.... nope. Ended up snapping off the brass connector!!! Nice puddle of brake fluid on the ground and no brakes :( Had to get the car towed to a garage for the repair.
At least you could still drive yours.
In regards to the reseal of the hood. Did you go anywhere near the overspill rubber slides (only way I could describe then) that are near to the inside of the hood flaps. As if you were moving the hood around these might have come out of their drain holes.
I don't touch brakes! I thought about just whipping the calliper off to get to the back plate easier but canned that quickly!
Cosmetic bits for me only until I can practice on a car that nobody needs to drive lol!
Re the overspill thingy do you mean this:
My car doesn't have it so I bought some but my car doesn't have any holes for the drain to plug into so can't be used on mine.
I think what I've done is:
its leaking from the sides only as per the pic above only, not from the back like before.
When I put the metal 'hoop' bit with the hood stapled to it back in a lot of sealant wiped off as it rubs the body on the way in (I did this singlehanded). So I reckon there is not enough sealant at the sides hence the leak. I've got some more butyl tape so will whip the hoop out and try that which should stay out when refitting. Actually writing this makes me think I should not attach sealant to the metal hoop but to car side only and the press the hoop up against it to avoid this....
FRANKIE
American Zeds
so in the spirit of @daveyhoogy and his Great British Headlight bake off and sharing his DIY escapade I thought I'd do some sharing and hopefully make myself feel better or at least amuse my fellow zedders...
So I've hardly been driving the car instead doing some jobs which included fitting these seats from @Brian H to go with the raid steering wheel.
But not before stripping them and fitting heated seat pads to them. Which work fine on the passenger side but only one pad works on the drivers - first frustration! The pads itself is fine as I can get each one to work but not both at once so something up with the car side wiring..beyond me at this point..grr.
On the up side the seats are much lower than standard and less padding really connects you to the car, feels bloody great, like a go kart!
The fitting of the seats and adjusting etc took some time but are almost there, just testing out seat spacers to raise the front edge a bit to get the perfect position. But given I've hardly driven it makes it hard to do...
So far it's DIY that's gone quite well really, if a bit back breaking whipping seats in and out...the heater seat pad is the only thing gone wrong so far...
Roll on Friday when I decide to test fit wheel spacers to my 17inch M style wheels...now I had a stud conversion to make this sort of thing easier but the 'rusty nuts' syndrome frustrated so I whipped them out and used the extended bolts that came with the spacers...no big deal right?
Well....I decide that the 12mm spacer on the front pokes too much so off it comes...I bolt up the wheel even torquing it correctly with my torque wrench..not bad for a DIYer.. drop the car and roll off the drive....
Horrible metal crunching sound...Ahhh I must have left the little metal wheel chock in front of the other wheel, no problem just reverse a bit so I can free it...more noise..
S**t what have I driven over I'm wondering, jump out and see lots of rusty fragments behind the wheel...ahhh I see the disc backing plate has finally rusted off I see...but hang on why has it just fallen off now???
So jack up car (after having put the £&@**+ trolley jack all the way back in it's hiding space in the far most corner of the garage tucked under shelving and boxes etc etc...)
Whip wheel off and look behind disc- see mangled up backing plate. Pull out bits of broken bits of plate and wonder what ********* happened here?
Sulk around being proper ******* off that I can't go for a drive on this fantastic evening and then I see it. The root cause of this DIY disaster- wheel bolts 12mm longer than they should be...yep I forgot to use the standard short bolts when putting the wheel back with no spacer...t**t is the word I believe...
So I pry out as much of the bent plate and think well the wheel turns freely, hey this isn't too bad just get the garage to put a new backing plate on at some point...then I remember that the whole hub made st come off for that job..getting costly now...
Anyhow, how about a top down drive to cheer me up I say as the wheel is turning freely now and no noises. Get off the drive successfully this time but hey hang on- why is the ABS and ASC light on???
Of course I've only gone and killed the ABS sensor that lives back there I guess...this is getting costlier...big t**t!
So roll on Saturday, not be deterred I decide as the forecast says no rain(sort of) for the weekend, I'll whip that hood frame off and refresh the butyl seal...
These are the only pics I took as for the rest of the weekend I was covered in sticky black goo...
Cleaning that up properly was fun...NOT. Especially as I had a bright idea a while back to try and stop the leak with silicone...who the f*** invented that stuff, I never knew its such a pain to remove as well!
Anyhow got all the surfaces spotless (and found the panel degreaser that body shops use dissolves butyl easily!) I cracked on with resealing it using some lovely butyl tape on a roll as suggested by @Lee - nice stuff to work with. I decided to be very thorough and run two rows along the entire body/plastic gutter.
Great.
But hey that left me about 30cm short when doing the metal hood frame/hoop to plastic gutter bit...aaaarreegh...!
Never mind I rushed down to screwfix, thankfully open on a Sunday and got the butyl window glaze sealant as kindly suggested by @Jjim
Now I'm c**p with this sort of stuff but I thought I managed to get a good even layer of it on so went to put bit all back together. Went well I thought until I realised I'd chipped some of the paint work ...aaargh...anyhow it's going back for a few touch up outstanding from the respray so I can get it sorted then I console myself...
So anyhow, Sunday is is over, car is back together but not had a drive at all...happy to see rain forecast for a change to test my new seals...
Get up this lovely rainy Monday morning ahead of a packed day, just enough time to pop my head in the Z and savour the moisture free interior...
NOT.. it's ********* leaking still, not as bad but still leaking!!!!
Just enough time to put some towels in to soak it up before going off to the office to sulk...
I decided late this evening after a long Monday to just stop doing jobs and just go for a drive. At least it's driving superb and the new seats, steering wheel and wheels really transform the ride, put a smile on my face.
Still ****** off about the extra work and cost I've created but I think I might just get over it eventually...think I know what I did wrong on the roof seal too so should hopefully be able to sort it when I regain the will to live and clean up butyl again...
Well if you still reading this thank you, this has been therapeutic. Think I'm going to lay off the DIY for while (famous last words!)
I'm not sure where to start with this. As I read this, I can feel the SAME EXACT feelings you had with some of the different things. When I replaced my hood, I had to take the seats out to get to the back hoop bolts. When trying to take out the driver's seat, it's so heavy for me that I damaged the plastic entrance plate with the frame of the seat trying to get it out. @GazHyde gave me some good information on how to tilt them first instead of fighting with them. When trying to take out the passenger seat, I was able to unbolt the front bolts and one back bolt on the rail but not the inner rail bolt which was tight and the socket kept slipping off. Tried 3 different sockets, same result...seat stays IN. When putting the seats back in, the air bag light doesn't go out. All connections seem good. Buy an electronic device that's supposed to erase the code and the light.............doesn't work...........light stays on.
I really had to laugh about the trolly jack. It's just a pain in the tail dragging it in and out of it's storage place. People who don't work on their own cars never realize this but sometimes half the work you do on many jobs on your car goes to time getting out all the tools you think you will need, especially if they're packed away somewhere in your shed (der hinterlands) or in the most remote part of your basement. The driver's seat in my 1.9 is too far gone to repair so I bought a beautiful replacement on e-bay for $100.00. The only problem is that it's from a Z4. I'm hoping I can somehow exchange the seats and the electrical connections which should be loads of fun.
As far as the caulk on the hood, I used a 3M product caulk which was waterproof but when I look back on it, I can't remember if it had butyl............uh oh...............I'll have to look it up in the store again. My car didn't have the drainage pipes you have, just a small metal box with a large hole at the bottom.
@Dino D, I don't know if you remember the post where someone had to replace a backing plate and rather that take off the entire hub, cut the plate in half and attached both halves independantly and, I think, somehow tacked the both halves together. Perhaps someone reading this will comment.
But I have empathy for you and the work you did. I swear I'll NEVER replace my master clutch cylinder again..........Grrrrrrr. Good luck with getting the rest sorted out...................................Frankie
Jjim
Mansfield
1.9 Roadster
View attachment 63975 View attachment 63976
The overspill plastic bits look different to this. I'll try and take a picture tomorrow.
When I reattached the hood I but the sealant on the side that was attached to the body, then slotted the hood down and in. That way the sealant didn't rub off on anything else.
Steve Medlock
Tenterden, Kent
I might not be able to compete here but I've fitted wheel bolts that were too long as well. Fortunately they were only'tinging' the back plate and didn't destroy it.
I did have a major cockup yesterday however. My rear wings are at the painters and the boot lid was just sitting in place as I was using the boot as a toolbox. Unfortunately I let the trolley jack down a bit too fast and the boot lid fell off. I was devastated to see the corner bent and the edges all paint chipped. I've eased the lid corner back into shape. I'll think about the paint chips another time.
hard top
Dutch Zeds
Netherlands
I am going to 'sticky' this thread as there (for the reader) could be some good stories.
Like @Faheem dropping a (not a Z) on his nut......
Dino D
Kent
2.8 Manual
Ouch!
I have a boot lid that's undamaged that you can gladly have if you can pick it up (it's Montreal blue so will need a paint).
Devon Z
Brixham, Devon
99 2.0 Individual
Just read through this thread and it made me feel soo much better! Thought it was just me that had Diy disasters? I sometimes wonder why I ever start some jobs!?
But we still do it and when it goes well it a great feeling.
mrscalex
Swindon & Swansea
If anyone else needs a bootlid or bumper covers just pull your car up to my Parents' house and I'll help you load up. No charge - happy to see them go before they get damaged in storage.
Dino D
Kent
2.8 Manual
Just to update on the roof- it's definitely leak free!
I spent another weekend removing the metal 'hoop' part of the frame that the hood is stapled to. That I did previously with the sealant from a tube and I didn't manage to get a good seal. Being on my own meant that I couldn't get both sides in without one side smearing sealant and not making ahold seal.
So I cleaned it all out (again) and used more of the one that came on the roll. This worked perfectly on the plastic frame to to body seal and perfectly on this too. I ran two lines of so used over 6m, probably over kill but a worked it with my finders to make sure it made a broad seal that had no way of water passing by and ensuring it bonded nicely with the frame before reinstalling.
All good now.
So lessons learned from the hood butyl refresh:
*the tape is easy to work with especially if you in your own.
*6m roll is not enough if you run two lines on both the hood yo body seal and hood 'hoop' to plastic frame seal.
*Those trim removal tools are bloody uselful in prying the old seals Larry and cleaning the old butyl.
*disposable gloves to go under workers gloves-butyl is nasty
*Panel wipe degreaser like bodyshops use dissolves butyl easily. I had a 5l can of the stuff for some reason, really good at removing the super sticky butyl remnants- just brush it on copiously and a stiff brush/Scott pad later and it's all clear.
*Mask the edges of the bodywork very well especially at the part close to the doors/where the hood will pivot upwards when you lift the frame. Lots of thick duct tape here to prevent paint damage as the metal 'hoop' part will run against the top of the wing as you lid it - really better to have two people for that part.
*Remove seats and roll hops for easier access
*Park in the shade before doing this job!
*Plan on a weekend (or two) and you'll be pease when you finish in a day or two!
Also got the heated seat pads working- was an easy fix, a bent pin in the connectir plug in the car side.
Now I have very toasty Sparco seats. Together the Raid steering wheel and Storm Greek on it really transform the driving experience as it literally feels more connected and you sit planted in your seat. Just lovely.
As for the ABS sensor...we'll need to sell some bits as that is ££ job.
These sort of trim tools, made life much easier prying the frame part and removing old sealant.
The two seals to be remade on display hear - the metal hoop part where the hood is stapled too. It is this hoop the can damaged the paint as it pivots(already cleaned in the pic).
The plastic frame that seals against the body is the 'dirty' bit in the pic before I took it out completely to clean.
When getting an new hood check if your hood supplier uses stainless steel staples... this car had a hood years back (I think carhood whareouse in Croydon) and evidently they didn't use stainless hence rusty staples that needed cleaning and treating (they weren't compromised so didn't need to start replacing them thankfully). I'll dig out the invoice to see when it was done.
Glad to hear others stories. I was fed up with this job but took a break and cracked on again and very happy now (well the A pillar seal leaked a bit when I was hosing it to check for leaks but that's an easy fix but I did swear a bit when I saw that! Now totally dry!)
@Dino D you have way too much spare time. you need to visit Zed Shed Lydney I can use you :whistle:
Good to hear you've nailed the sealing job Dino.:thumbsup: As you say a messy job but it needs to be right.
Dino D
Kent
2.8 Manual
Not enough time hence taking two weekends to do this when others do it in a day!
Car hasn't even left Kent since last years BMW Hq run...got cobwebs in the filler flap it get used so little, even at 20mpg it's taking me ages to use a tank!
But as you've erm...'matured' and gone the softy Z4 option I'll come help you out and get one of the S50's off your hands :)
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Just you wait @Dino D, the day will come when you succumb ........ he he.
Good job on the roof BTW :thumbsup:first prise for patience.
Jonnysnapzzz
Nottingham
Whipped out my drivers seat last week to install new bushes due to slight movement. I was so careful after all the stories on here of scratching this and that.
Anyway I got them out without a problem to find the bushes were fine, already done before I owned the car.
So back went the seat and bloody snapped the seat belt guide! All for nothing! Gutted
