Zedders in or near Sheffield please can you take a look
Redline
Nuneaton
E89 20i msport
Its only a 1.9 but is still on the road by the looks of it.
Have found an E85 and E89 Z4 too - You could have a whole set!
You could always get @Sean d to paint it for you Stacey !:)
Dino D
Kent
2.8 Manual
Guess its the labour to do the gearbox and diff (or can they be done while on the car?).
I think it's the valve clearances- the normal engines do not need valve clearances adjusting but the M engines do.
Plus M tax as you ideally want to go someone who works on M's regularly (so not your average main dealer as they are tractor parts and turbo replacement specialists these days!)
yocky z3 2.0
Cudworth barnsley
Z3 2.0 roadster
Has you all know I had a look at the Dakar m for Stacy on my way home from work on Thursday, met Gary the owner at Morrison hillsbough just as it was starting to get dark would have preferred to have seen it in the daylight.By what I could see the body work is in good condition and the interior as well under the bonnet the engine was warm so could not listen to the vanos from cold but on tickover it ran smooth,on taking on a run the car felt nice and tight on the road with plenty of get up and go as it should.Gary has had some work done eg new clutch,two front calipers,discs and pads also a ns bottom arm and bush.The bonnet as been painted due to stone chips but I think it as been changed at some time when I was looking under the bonnet some paint had rubbed off and I could see some red paint under it Gary says if it as been changed it as been done before he bought it the mirror bases will also need re painting not mint but with a bit of tlc I think will make a nice car unless I have missed something which mark and lee pick up next Saturday when they go to see it in daylight also a bit of movement price wise I think cheers tony.
Tfp
Cambs
Had the dealer warmed the car up before you arrived?
If so, that'd have my alarm bells ringing.
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
Thanks for looking @yocky z3 2.0. I'm sure between myself and @Lee we will pull it apart
Tfp
Cambs
Call the dealer the day before and tell them you want to start the car from cold.
When you get there feel the manifolds for heat.
Sorry if I'm telling you something you're aware of.
I guess the friendly bank manager said yes then Stacey. Hope the car is good, you've got two good guys to check it out. Chuffed for you mate. But you'll have to come up for another steak pot pie and show it off at Torksey.:)
M
M666BMG
Guest
Yes then everyone can sit in her car !
