Check the date of this post. May 05th. 2020. All sold now.Yes please can I purchase a set
These straps are pretty much not available new any more good second hand ones also difficult to obtain this is why @Mazza designed the ones he didHi Tony , I was trying to get some interest to see if any member knew where I can purchase a set
Thank youThese straps are pretty much not available new any more good second hand ones also difficult to obtain this is why @Mazza designed the ones he did
But if you read through the thread you will see due to spiralling manufacturing cost and lesser demand he did not go ahead and get more produced so more than likely now you will just need to keep your eyes peeled for either a spare set of Mazza ones someone has lying around or a decent condition second hand set to come up for sale.
Stephen.
Thank you
Had a set put on my current Z the garage doing the work were very impressed, and good value for money. GeoffNow available on the "For Sale" thread. Pm @Mazza for a set.
I would obviously like to place my order , thank you for all your hard work if you could pm me I will arrange paymentAs of today I have 100 sets ready for despatch.
Each set comprises of the following :
N/S and O/S two part tank straps in 4mm mild steel finished in black powder coat.
Qty 4 M6 Nyloc Nuts
Qty 4 M6 BZP Washers
Qty 2 Cable tie anchors
Qty 2 Cable tie M2.5 x 100 black
Qty 3 Nitrile rubber cushions (270mm, 330mm, for O/S and 350mm for N/S). ( can be fitted prior to despatch if required)
Price : £65.00 per set. Plus postage at cost
Please PM me to order/reserve a set.
Please Note:
The Z3M, will require an additional part (which fits to the N/S bracket) and is still in development, but will be available soon.
Pm mazza direct.I would obviously like to place my order , thank you for all your hard work if you could pm me I will arrange payment
All donePm mazza direct.
Full instructions and DIY if you are comfortable crawling under your car on stands and have a steady hand (for the cutting bit). My local garage charged me less than an hours labour to fit mine which was much more preferable.Have also PM’d Mazza, is this an easy enough DIY job? Any instructions or videos? Will be buying regardless!
Hi there . I'd love order a set of straps for A BMW Z3 , 1.9 , 1997 . Thank youAs of today I have 100 sets ready for despatch.
Qty 4 M6 Nyloc Nuts
Please Note:
