Classic Coachworks dealt with getting the V5C changed to readSo theres no need to send in the form V627
Sorry. Now I'm confused. A few posts ago you said that the MOT tester made the changes for you. But now you're saying that CCW did it for you.Classic Coachworks dealt with getting the V5C changed to read
Make: TRIBUTE
Model: Z75
The V5C is the key document. Everything else can be changed to reflect what it says, and use it as the authority.
The V5C can only be changed with the agreement of DVLA.
CCW arranged for DVLA to change the V5C. The MOT tester changed the MOT database, and used the new V5C as the authority.Sorry. Now I'm confused. A few posts ago you said that the MOT tester made the changes for you. But now you're saying that CCW did it for you.
OK. So now I understand.CCW arranged for DVLA to change the V5C. The MOT tester changed the MOT database, and used the new V5C as the authority.
The v627 will change the V5c.So theres no need to send in the form V627
I probably hadn't drunk my usual amount of coffee but I understood pingu to be saying that the mot guy could change the data as in the v5 data. After the 3rd cup I clicked what was meant.The v627 will change the V5c.
the tester can Amend his database to match the V5c, but he cannot amend the Dvla database.
so you will need to send off the form. It’s an easy change to make.
