Nice write up mate. That car really looks smart now. Look forward to seeing it. You at vanity or santa pod in the coming weeks ?
It ran mate, other than that no idea, bought it for spares for my 2.8 track car. But change of circumstances means it needs to go.@spurs fan in a coupe is the engine ok in the donor car?
ok thanksIt ran mate, other than that no idea, bought it for spares for my 2.8 track car. But change of circumstances means it needs to go.
Great spot Andy...guilty as charged...spotted I believe the Mints...
Hi pretty much, just ordered the LHD clutch line from the pedal master to the slave, the new bearing and rear seal and the running shaft the clutch bearing sits on.You got the bits now mate ? prop shafts etc.
Can’t wait to see this all come together make sure you take plenty of juicy pictures.Hi pretty much, just ordered the LHD clutch line from the pedal master to the slave, the new bearing and rear seal and the running shaft the clutch bearing sits on.
Is it worth getting the prop balanced, going to renew the vibration rubber anyway
I have everything else including lightened flywheel, M3 clutch braided hose and bearing, will order a new slave cylinder and get a short shift and stormwerks while Im about it, so everything is as good as it can be.
Hope to have everything in the next week,
Andy
Hi yup diff, lollypop and subframe bushes I believe, sorry for not making it down, god I'm even starting to miss Paul.@windym remember you have a load of bits still sat in my garage mate. Not sure what powerflex parts they’re for. Buried under my Porsche bits.
