So the heater box has drain holes?Once you’ve removed the scuttle panel you’ll need to poke something into the drain holes to unblock. Then simply clean up and reassemble.
I haven’t even considered this. It makes sense, it’s been quite a few years. Is replacement inevitable you think? I have done little maintenance on my top side from covering it. Thank you for the reply !Top has shrunk
Stephen.
No. The under scuttle space around it does. This is what blocks up and creates a swimming pool.So the heater box has drain holes?
Perfect, exactly what I needed. Thanks
