Upgrading shocks on 2001 Z3 3.0i roadster
Peimli
Hi guys,
I want to exchange my original shock absorbers and springs.
I either would like to keep it the original stiffness or slightly stiffer perhaps as I’m worried if it’s too stiff it would damage the subframe.
I was thinking a set of Bilstein B4 or a little harder B6.
Any experience with these? Or perhaps any other options?
Jjim
Mansfield
1.9 Roadster
Madtoady
Rochester, Kent
3.0i Roadster
I also went with the B12 pro Shocks and Eibach 30mm lowered springs. Drives like a dream!!!!!
Peimli
The only problem I have against lowered shocks and springs in London are the speed bumps. I wouldn’t be able to get around:/
Mario
I also went with the Eiback -30mm and Bilsteins - I hardly ever have any problems with speedbumps unless I am carrying a heavy passenger... you could just change the shocks to Bilsteins and keep the factory springs
mrscalex
Swindon & Swansea
First of all I would search through the forum as there is a lot of previous advice which is difficult to distill succinctly.
And I’m no expert on modifying. In fact I’m an advocate of keeping things standard.
I think the 15mm drop on a factory Sport is perfect. Going the extra 15mm to 30mm puts it too low and at risk of underside damage - in my personal opinion and experience.
If your original springs are not broken or corroded badly then consensus is they can be reused as they don’t gradually lose their effect like shocks do.
If you do replace them though then I’ll happily buy your old ones and put my money where my mouth is :)
If you are on original shocks then they are quite probably long since knackered. Bilstein B4 or Monroe Reflex shocks are not regarded as performance items like B6/B8 but don’t need to be to do an excellent job. They are both well regarded on this forum and avoid the insurance issue.
I recently used Monroe Reflex and H&R (direct rival to Eibach) -30mm on my Sport. The ride was transformed but as mentioned too low for me.
It follows I will also say BMW shocks (Sachs) and springs are also good in my book but they are expensive.
You will not find replacement -15mm springs from anyone but BMW. Which is a great shame. And why I will buy unwanted Sport springs.
But you must also look at other factors which affect handling if you want to tighten up the ride and frankly make the car safe. In particular a rear end refresh as done many times by the Zedshed on here. The need for new rear beam bushes are an important factor too on most of our cars now.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
I have just fitted new Sachs front struts @ £65 each delivered. 5yr guarantee.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
I just refitted my Eibachs and Sachs shocks coming from cheapo coilovers. Although not as low as I'd like upfront the ride is a lot better, less bouncy and crashy. I could just about clear most things on the coilovers and it was low at the front especially with the splitter, now I can clear anything and even get on and off the drive without ripping through the underside. I've heard nothing but praise for Bilstein shocks.
Peimli
Which bushes would be advisable to change? And besides the bushes what else would need to be changed by your experience?
mrscalex
Swindon & Swansea
Be careful, you'll wind up taking the back axle out to change everything. Hell of a job to do, but well worth it. The front end bushes are relatively easy to do.
It’s just about the only job we’ve never tackled before. Although we’re in the middle of our first attempt. And we’re doing it the hard way bit by bit to avoid removing the exhaust.
We initially had a nightmare getting the old beam bushes out trying different methods. But in the end a combination of a 12 ton hydraulic press, the right pressing cup, heat and a strategic manouvre with an angle grinder and it just glided out :)
Peimli
OMG That sounds like a hell of a mission!
