I can second the Lidl unit , had it a couple of years and found it very good.
Give me a shout when you want me to come and have a look at getting the electric sorted.For the five years I've owned my zed I have always just disconnected the negative terminal and left it. This has usually been from November to March. Never had an issue with the electrics after.
Now I have moved and have a garage I am going to start using a conditioner once I get electric plummed into the garage.
They had loads in ours when I got one, normally I've missed out in the past. They tend to get them in a couple of times a year now. At least your slow out the blocks, he struggles even getting to the blocks at his age.I was going to get one of those last year Dave, but, being slow out of the blocks at almost 70 (ask your old man) they were sold out mate so I got the Voche one.
You can pop anytime Jim and have a look mate. Probably be after Xmas before I get onto it though.Give me a shout when you want me to come and have a look at getting the electric sorted.
No Aldi near meI got a Lidl one when they were last in, never have the car off the road so not used it yet but they get great reviews just like the CTEK's.
Aldi have their version coming in store from Thursday https://www.aldi.co.uk/auto-xs-car-battery-charger/p/097043233607400
They will all work. I’m sure of that.never had any issues from using my cheap one..
as long as we are both happy with our individual purchases and experiences... thats what matters.They will all work. I’m sure of that.
Here’s some advice I got from one of the power guys who maintain standby generators often located on top of cold hilltop sites.
Charging is simple. To be effective over a long period unattended a charger has to do a number of things.
To be effective your charger should run three stages.
Constant current phase
Topping phase
Float phase.
The topping phase (reducing current) can take twice as long as the constant current phase. 6+ hours compared to 3 hours or so.
It’s the float stage that is important to batteries only on charge 24/7.
If your charger doesn’t properly float charge it constantly create heat and it will eventually hurt the battery life.
The float charge should be increased or decreased depending on lower or higher ambient temperature.
Even float charging will reduce capacity over time, but you’re talking several years to reduce to 85%.
Pulse charging is claimed to recover from sulfation of the plates. That occurs when a battery is left discharged before recharging. There comes a point where that recovery can’t be achieved. Pulse charging is something that many say has little or no effect.
Some chargers disconnect the battery from float charge to allow self discharge and then reapply charge current and maintenance voltage. If the battery is in the car, the parasitic load will drain a little out of the battery and the charger will kick in again later.
When charged the plates also effectively have a capacitor effect. This has to be removed to get a proper voltage reading.
So, there’s quite a bit to think about if you’re putting a battery on long term charge.
Hopefully that explains what a battery conditioning charger has to do. Damage may not immediately apparent from incorrect charging.
Was just trying to explain the complexity of maintaining a battery that’s unloaded and potentially outdoors.as long as we are both happy with our individual purchases and experiences... thats what matters.
I can offset the £50 difference against my next battery.... whenever that is.
It works for me, and I've not noticed any increased purchase in batteries to be honest. Each one lasts beyond the battery warranty offered, and that's with each car I have had.
