When I collected the Elf from
@Mark Parrish &
@VV54 last week Marks first word to me were - "you don't need to refresh the aerial grommet it's already been done"
He also told me that the clutch and tank straps had been replaced which he had previously forgot to mention before I agreed to purchase the car. In fact going through the service history there were quite a few things that had been done relatively recently by which I mean in the last 10,000 miles / 3 years.
So on the basis I have nothing to do to the car I thought I would just capture a list of what has been done - joking aside I do like the progress threads that build over time so I thought I'd have a go at doing the same, alongside me recording my various trips out obviously.
So here is a list of of what's been done which I will maintain and update over my period of ownership - which as most of you know is likely to run for a good few years
Replacement DME, EWS, Ignition, Door & Boot Locks and key
New steering fluid cooling system
Lamda sensors replaced x2
Camshaft sensor replaced
MAF sensor replaced
Style 42's refurbished in gloss black and new Uniroyal rain sport tyres fitted
New front struts and springs fitted
New wishbones, drop links, track Rod ends fitted and all Bush’s replaced
New splash guards fitted
Wheel bearings front and rear replaced
All calipers stripped and refurbished and painted Elf green
New brake hoses front and rear
New brake hard lines
New discs and pads all round
Refurbished spare wheel and carrier
Rear beam and trailing arm Bush’s replaced
All ARB Bush’s replaced and rear drop links fitted
Diff removed and painted
Diff, gearbox oil renewed
Vanos overhaul new seals etc and solenoids
Cooling system overhaul to include pump, thermostat belt and tensioner and coolant replaced
Inner sills clean no rust and treated
Outer sills repainted
Roll hoops fitted
New rear window fitted
New clutch fitted
Tank straps replaced
Zedonist Angel Eyes - Indicator Daytime Running Lights fitted
Sparco strut brace fitted
New febi washer pump fitted
