S50 progress thread..
i'll stick with the conti's i recon...altho i'll see what comes along ;)
they must be...there gona last you a life time :ymdevil:
just inspection 11 done along with the suspension finished off.
no shims needed
new gearbox and rear diff oil done
new rear brakes put on along with new carriers/pads and fluid.
the powerflex bushes were taken off as they pushed the front wheels to far forward...so we just stuck with new OEM on it.
not had chance to drive her proper yet but first impressions are good...much more planted...firm but not crashy...gears and final drive very smooth.
just need to add up the final bill now :-s
no shims needed
they will call you the pelican :ymdevil:
been called worse :))
little update..put half a tank in .... purely for experimental purposes you understand ;)
half an hour later and shes flat through the corners and i would say a good 20% faster around them before i felt i was pushing it.
however this extra speed is now contracted by the fact i have to crawl over speed bumps or pot holes :))
also im going to say that i never really bought into the fact the the the service light reset improves the performance ...but there is better performance...maybe down to new oils all round new plugs and filter other bits of magic they do...who knows..but it can only help anyway.
all in all im very impressed
pelican (everywhere you turn there is an enormous bill in front of you)
A jokes never good when you have to explain it ;-)
Its always a nice feeling when a cars sorted swamper :grin:
Ive just been for a run in mine on some twisties and it makes my daily msport feel like a whale. You gotta set it up on the side of fun over comfort :twisted:
its fun..i'll just have to see how it fairs on the long runs now.
i'll leve it a couple of weeks and get the tracking done on the advice of the indi when its all setteled down
red or yellow stuff now...still undecided which to go for yet.
but next is some new rears on i reckon...there not going last much longer with the way in testing out the new mods :ymdevil:
Slicks in this weather is fine officer, more grip :nearmiss)
I'm not sure I'll be keeping up with you on the next cruise Wayne, it sounds like you have a right little gem of a car there mate :-bd
I found this info on the EBC website, it may help you make your mind up which pads to go for.
Ultimax - General replacement pads
Greenstuff - Performance upgrade and far less dust
Redstuff - For cars producing over 200BHP
Yellowstuff - Track and fast road
Bluestuff - Endurance racing
its a petty i cant try them all out first Pete.
euro has just quoted me 131 all round for red stuff
edit......its you lot that take some keeping up with...you all forget...iv seen you go for it :-o
:ymdevil:
new plates.. :ymdevil:
I can recommend yellowstuff fine even from cold normal dtiving nice feel little dust and no sqeeking after initial coast is worn off.
cheers Jon....its looking like the yellowstuff... ;)
on there way ;)
yellowstuff is here and we have run into a small problem... :-\
the car is now so low that i cant get the jack underneath it to jack it up.................bugger :))
Couple of planks of wood under the front wheels should sort it. ;)
iv stuck it in the local indi.........sod it......he had a good laugh :))
