Well no not really. I have no problem with the drain catch cube at the top and the drain tube in the bottom of that. On the inner face of the B post, there is a rubber bung about 80 x 25mm. If you remove this, you can see the tube and that it goes down to the top of the inner sill. My drains aren't blocked but, I was trying to figure out where the water actually went and how the soft top drained. Thats went I tested it with 300ml of water and saw that it came out of the sills at the join between the sill and the floor (outside underneath) as it is intended to. My issue is that the drain system introduces water from the soft top into the sills and causes the sills to rust, unseen, from the inside. So, my quest is to find a way of extending the existing tube so that it drains to the outside without dumping its contents into the sill box void. I won't know how I am going to do this until I remove the sills this Winter. I just wondered if anybody else had done this mod before. Having figured this out, I am not happy with it and want to come up with a solution to prolong the integrity of the structure that is out of sight.
