Just need to pick someone brains !!! ( and confirm that I have thought this through correctly!!)
The black plug in the photo is the connector for heated seats that is located under the seat.
Have confirmed today that BMW ‘own’ the mating half and the crimps, so they are not available to buy on their own.
Sod it !!
After checking the new heat pad wiring kit, I think I have found a way of making the least amount of connections by taking out the crimps from the pads 2 way plugs and reinserting them all together into a 4 way plug ( ie seat and back in one connector as I would assume they are in a factory fitted heated seat.)
As I only actually need the heat pads ( I think !), most of the wiring that came with it will be redundant any way.
So I can take the bits I need.
I just want to confirm that the relay that came with the kit is not required and that there is one somewhere in the Z3 wiring loom already.
And, That if I cut the black connector off, it is ok to solder , heat shrink and sleeve the 4 wires ( 2 brown and 2 white) to the wires of a 4 way socket ( which can be cut from the new loom), and this then will connect with my new 4 way heat pad plug.
