Did he manage to perform any magic and make the roof come up remotely?Just 40 minutes to fit a switch and code it. Clever chap. He also coded a couple of other bits with his Carly too.
Thought that would be the case, but you never know what wizardry some people can do with a tablet or laptop.No, not possible. A “Smart Top” module is the only way and they’re almost £400.
If you interested in one I'll keep a lookout on z4forum as they do come up on thereNo, not possible. A “Smart Top” module is the only way and they’re almost £400.
Its a must. great guy and so quick.Left home for Grantham this afternoon around 2.10, arrived around 4.30 (ish) . 40 minutes later I left for home and arrived around 7.15. The A1 was a nightmare, as were all the local roads and villages. Anyway, the upshot of the trip is I now have Cruise Control on my E89.
Don't forget you can close the roof with the key in the drivers door lock, saves you getting back in the car if you have left it down.No, not possible. A “Smart Top” module is the only way and they’re almost £400.
Can't get that to work on ours, does it require the comfort access pack?Don't forget you can close the roof with the key in the drivers door lock, saves you getting back in the car if you have left it down.
Works on all of them. Put the key into the lock, turn the key to lock position and hold. If nothing happens or just the windows go up, unlock with key and repeat, keep the key held in the lock position until the roof has completed the cycle.Can't get that to work on ours, does it require the comfort access pack?
No I dont have comfort pack, however there are still options in Carly to change comfort settings and they work without the comfort opening installed, the roof being one of them, I just assumed all e89s were set to active for the roof closing on the key /lock. Takes a few mins to change if you have access to a Carly.Can't get that to work on ours, does it require the comfort access pack?
Just need the roll hoop rear covers to match TonyWell, .............. I knew this would be devisive, but, .................................. I did it anyway. Because,
View attachment 198267View attachment 198269View attachment 198271View attachment 198273View attachment 198275View attachment 198277View attachment 198281View attachment 198283
I like itNow you see why the red centre caps Dawn @ktnez99
