So
@Dave has had some tough decisions to make with his Zed build. The last item to come out last Saturday was the gearbox and boy did she throw us a curve ball.
At this stage of the build and no previous knowledge the clutch had been changed Dave wanted it replaced and rightly so with 203,000 on the clock. The lower bolts on the box removed with no issues, all the top bolts however all fought us.
The main bolt at 12 o’clock fought so much we ended up with a 1/2” bar and a 4foot scaff tube trying to undo it. Finally it snapped. Problem we then had was no access to extract the old bolt and two others also snapped. So the gearbox was stuck on
As a team in the shed and how much this car means to Dave we collectively came to the conclusion we were happy to remove the engine but Dave had to make the decision financially.
So the last two days on my Tod I removed the engine
I didn’t take a huge amount of photos but enough to get the gist.
Inlet manifold removed. This then allows access to the rear lifting eye
front clam spot welds drilled out.
Quick peak at the valves.
Relatively new alternator
Front removed. And this concluded day 1 in this crazy heat.
parts building up.
day two was another fiddlery day. Aircon pump removed so we don’t have to open the system. Same with the power steering.
Bit of swearing and puffing she’s out.
looks like a right mess
finally onto the main event. After some swearing I managed to get the start motor bolts to move and she was off.
close up showing this clutch assembly is not 203,000 years old.
Plenty of meat on the disc
pressure plate
flywheel
Next I tried to weld a nut onto the broken bolt and it was having none of it. Still a little warm in this photo, so it will need to be drilled out.
We also have a repair to do to the engine casing, one of the bolts got upset on the way out. Luckily both guys here can ally weld.
before I left for comedy value I thought I would see the condition of the pivot arm. Not much life left in that.
how I left her for the day. I’ll pop in on my way home from work tomorrow. The exhausts are also now removed.
Exciting
