A couple of people who know I have done this once already and planned to do it again on the 250 Cal, asked me to write up a how-to. So here it is:
First Question
Why bother?
The M52TUB28 was artificially restricted in it's breathing ability by BMW. Why? Well, rumours abound:
This photo probably tells you all you need to know, the increase in airflow is around +15-18% which is huge! Just look at the oval 2.8 and the fully opened out D of the 3.0. The size difference of the DISA's probably tells you even more.
From experience of the swap from M52TUB28 to M54B30 manifold/DISA and ECU to allow for adaption, the difference in performance is huge. Normal 2.8 torque and performance up to 3750 revs then all hell breaks loose, the acceleration is maintained right up to the red-line which come up very quickly.
Best bang for the buck performance wise on a 2.8 double vanos (if you have single Vanos use the M50 manifold from a 2.5, well documented elsewhere).
First Question
Why bother?
- The 2.8 had to be kept below 200bhp for German Insurance / Company Car reasons - I have never seen any real evidence for this.
- BMW knew that they would add the 3.0 engine to the Z3 with 231bhp on tap, the 2.8 would run at about 215-220 with a decent, unrestricted manifold and DISA. Not enough of a difference to warrant the price difference. - I find this more likely.
