nooooooooo, see how much you can make before turbo first
im curiouse as to how much can be freed from dumping the fan, water pump, power steering and anything else connected to the engine.
I fitted a strut brace for a 3 series on my Z3 Andy, so suspension dimensions look to be the same, so there's a fair chance the engine compartment is the same. Always nice to have a source of information when doing something like this, but it is a problem talking to someone who is 5 hours behind you. It doesn't sound much but it means you doing polar opposite things like at the end of your day he's only halfway through his work.Hi, thanks @t-tony for that info may well come in handy, just talking to a chap in the states selling a custom turbo header/manifold and Garrett T4 turbo for the M44. Apart from the time gap with messaging he is not so keen on posting but will see what happens, at the moment I am trying to work out if it will fit the Z3 and if the 318ti engine compartment are the same.
Looking at the work he has carried out and the dyno his car is putting out 263 HP, with 15/18 lbs of boost. He says he has been running this for 18 odd months with no real problems, my thought would be to use less boost and aim for the 230/240 HP mark.
I may well use his build as a reference.
Andy
I have a contact in Pennsylvania that it could be posted to and he in turn could post it to UK if that helps.
Keep the info and pics coming please! Very interested in the while project, JIM
doesn't swapping mechanical pumps for electric ones just move the power drain to the alternator? does anyone have figures for how much hp is used to generate say 50 amps?
The 1.8/9 steering rack is the fastest and lightest on the Z3 range and also can be driven without PS, with the use of a by-pass valve. I may go fully manual if I have trouble sorting out the pump but the pressure by-pass has been used by a couple of E30/6 racers in the States. By all accounts works very well and can help to reduce tram lining and give a more planted feel to conering (their words not mine)
Andy
i thought all Z3's have the same rack and the same ratios hence why people put them in other BMWs. RealOEM certainly only shows one part number for all Z3s
i personally wouldnt bin the power steering as its hydraulic and has plenty of feel as it is
That would be because I wasn't told about that by Sean who told me everything sounded good to go! So sorry but I think you are doing okay overall from it, JIMYou should be.... it's your old engine!
You never told me the water pump and head gasket were gone when I bought it!
