Daspete
- Joined
- Jan 13, 2019
- Points
- 60
All ideas are welcome Steve. Seems quite logical. I dare say if this is the issue then I'm snookered. A custom pick up wheel is just not possible.Here's another thought is it possible the cam wheel pick up point is at a different timing point and the dme thinks the timing is out as both cars crank sensor should pick up tdc but if the cam pick up point is a number of degrees different could throw up the fault ( have had the m44 apart but not the m43 as funnily enough it's been the more reliable and economic of the 2 of mine ) so it's just a thought as at the end of the day if your stuck any idea is potentially a good one ( or not )
Stephen .
Being a late model i assume a change of ECU will mean things won't work properly .
Looking like the M43 is getting rebuilt doh!!!
