'Izzy' (2.8 widebody)
Reupholstered wheel, gaiters and handbrake handle fitted
And with that, I was able to pull the car out and fit the freshly serviced and painted brakes.
This weekend I replaced the thermostat, water pump, rad hoses and drive belts. It all went pretty smoothly and the temp gauge is now dead centre and the heater is blowing lovely hot air. I just need an excuse now to go for a drive and give it a shake down.
I wasn't able to find the block drain, so only got 5 litres of the old coolant out, so I'll probably change it again next year and give myself a bit more space to properly get under and try to find that pesky drain!
...I just need an excuse now to go for a drive and give it a shake down...
Surely that is a excuse reason to go for a drive, it's a shake down test after all.;)
But if you need another reason I am always willing to help a forum friend in need, we could always meet for a coffee/chat:thumbsup:
I take mine for an Italian Tune just to get it dirty so I can wash it ........ and repeat ......... for 9 years.
I took Izzy for a proper shake-down and commuted to Derby yesterday. Fun little drive along the back-roads and nice to be out in the Z3 again after a few weeks.
Coolant system behaved perfectly and the retrimmed steering wheel felt great. Made the road tax and insurance payments worthwhile 😁
Oh my word, what an absolute sh*t-show of a weekend!
It started off really positively, I went out Friday evening just to get the front of the car on jack-stands, so I could crack straight on with replacing the AC fan on Saturday morning, but I ended up 'just another 5 mins' for about an hour and completed replacing the fan before I came in. I can get it booked in for an AC re-gas now.
Buoyed by that success, on Saturday morning I went about deleting the secondary air pump, and finally fitting the blanking plate @t-tony sent me months ago. Another item ticked off the list.
I should have stopped there 🤫
But no, next thing was replacing the lower control arms. I already knew one of the ball joint boots was torn by my own doing last year when I replaced the knuckle, but checking the last MOT advisories (which is due in a few weeks), I remembered that it had advisories for play in the ball joints too, so I thought I'd replace the control arms with the ones I fitted new to my first Z3 last year, that I bought back off the guy who bought what was left of the blue one (still following me?) Anyway, I found that the ball joint covers were torn on those ones now too (again, at least one of them probably by my own doing, I'm guessing there is a knack for using a ball joint splitter without tearing the boots?)! Bugger. I have ordered another pair of arms which should come this week and carried on with removing the old ones...
Offside
Disassembled the brakes, undid the knuckle ball joint. Started undoing the chassis ball joint when the corrosion on the threads caused it to seize up and the whole ball joint was just spinning. And the hex/torx hole on the top was so corroded, I couldn't get anything into it, nor was there enough space to hammer a spline bit in anyway. However it was loose enough to split the ball joint though, so I did that and then undid the lollipop bush bracket. With that the control arm was just hanging down by the nut on the chassis ball joint, that I still couldn't undo.
I thought I was being clever by angle-grinding through the exposed ball joint stud, the arm would fall off from below, and I could lift the stud and nut out through the top, right? Nah. This is when I discovered the stud is tapered, and now I just cut away any material I could use to hold against the torque of undoing the nut. I was a bit stuck at this point. I grinded out a slot in the bottom of the stud for a flat-head screwdriver, but I couldn't go very deep before I would have been grinding into the subframe, and with the torque of trying to undo the nut, the screwdriver approach wasn't working. I thought I was going to have to find somebody who could come out and tack-weld the bottom of the stud to the subframe, but I thought I'd take a break and switch to the nearside first.
Nearside
Carbon copy of the offside, except this time I knew not to cut the control arm off!
I've had an induction heater in my Amazon basket for a few months now, so I decided now was the time to pull the trigger, and ordered one to come on Sunday. I wasn't sure this would help with my butchery on the offside, but I was optimistic it would get the nearside one off.
On Sunday morning while I waited for the Amazon delivery, I took the powerflex lollipop bush & brackets off the former-donor arms and cleaned them up, and while the front discs were off, I cleaned up and painted the disc hubs black.
I also removed the front-anti-roll bar and was going to start sanding that down and giving a fresh coat of paint, but the Amazon delivery turned up so I turned my attention to the induction heater... It's big. Too big in fact. Even with the airbox removed, it wouldn't fit down the side of the engine to reach the nut, and the wire coils that came with it were rigid, so I couldn't attempt to come at it from below either.
To my surprise, I tried the nearside nut again (via socket wrench and a number of extensions) and this time I got some movement from it. I'd like to think it was the sight of the induction heater that scared it into compliance, but really I expect it was the copious amounts of WD40 it had been bathing in for 24H that finally did it! I went back and forth a few times, applying more WD40 and wire brushing the corrosion off the threads, but I still couldn't get it past the last few threads. Eventually, through shear desperation, I put my jack under the ball joint and took some of the weight of the car onto it, and that was enough resistance on the ball joint to undo the nut. Finally that was one control arm out!
I went back to the offside, there was no ball joint to put the jack on this time, and what was left of the stud went higher into the hole than the lower face of the subframe - if that makes sense, so the jack would have just pressed on the subframe, rather than the stud. I found a nut that was small enough to fit the hole, and a piece of scrap metal to stop it just pressing into the jack pad. I couldn't put enough torque on the nut with a spanner from below, however the jack was holding the stud still, which was a start! By disconnecting the earthing strap and now the secondary air pump was removed, there was just enough room to get a socket and extension onto it and I cracked it from above. I don't think I have ever put so much force onto that wrench, I thought I was going to break something, but I got the nut off and after I removed the jack, a quick tap on the stud with the spanner and it fell out. Second control arm out!
Christ almighty, what an ordeal!
If I ever do control arms again - and I am writing this here to remind myself more than anything - I am going to remove those two ******* nuts before jacking the car up
I fitted the replacement control arms one evening last week and got the car mobile again (although missing the front ARB). Meanwhile over the course of the week I hand-sanded the ARB down to bare metal, sand-blasted the brackets and painted it back up again. Rebuilt it with new Delphi drop links and Powerflex bushes.
Much better!
Despite having a nasty cold and feeling pretty rough, I made the most of the weather this weekend by re-fitting the ARB, along with new fuel tank straps (thanks @Mazza) and gave the wheel arches and the inside of the wheels a thorough clean. Finished the weekend off with giving the whole car a wash, clay-bar and polish. Just in time for the rain this week :rolleyes:
MOT is in two weeks, I just need to get the tracking done as it is out, hopefully it's due to changing the control arms rather than that there is a problem.
I went for my tracking to be done on Wednesday last week, but the garage said they couldn't do it (despite having no problem a few months ago when I was messing about with coilovers... but anyway). They said the spanner was slipping on the rod, there wasn't enough thread to adjust and that I should replace the inners and outers. Regardless. I already knew one of the track rod end ball joints had been pierced and was leaking grease, also the crusty track rods next to the new control arms and refreshed ARB was hurting my OCD.
I ordered a replacement pair (Meyle) that arrived on Saturday morning. I've never played with the steering system or track rods before, so I was a little apprehensive, but fitting was surprisingly straight forward and I think I did a pretty good job of setting the tracking 'by eye'. I've got another appointment for the tracking to be done this afternoon, so it should be interesting to see how far out I was!
Edit: Tracking done! One wheel was pretty close, the other was miles off. Sadly no Rain Man-esque natural tracking abilities unearthed this time =)) )
Last weekend I painted up the replacement wing I prepped months ago. I was happy with how the (rattle-can) basecoat went on, however it all fell apart with the clear coat which might as well have been made by Del Monte with the amount of orange peel I got :confused:. I tried to recover it with wet sanding but it wasn't happening, so I took it back down to bare metal and primed it again. This time I have bought proper paint, thinner and clear coat and am going to have a go with the compressor and spray gun this week.
MOT passed! And without any advisories - the last time this car passed first time without any advisories was 2012! I am feeling pretty pleased with myself.
Painting is proving more challenging however. Almost certainly due to using the spray gun that came free with the compressor, and also me having zero experience - obviously.
I wasn't horrified with how the basecoat went on, even if it wasn't a mirror finish, it went on reasonably evenly and smoothly.
However the clearcoat was a disaster. It was coming out of the gun so thick and splattery, that to get full coverage meant it was literally dripping off the bottom edge.
Once dry it looked a bit better, gravity had done a reasonable job at evening it all out - with the exception of enormous runs and lacquer stalactites at the bottom. And a dog hair that found its way into my DIY paint booth (aka dust sheet stapled to the ceiling in the garage).
I left them a few days to fully dry out and then attempted to wet sand them, starting with 1000grit, however before I got close to leveling them out, I had gone through the basecoat and primer on the edge. And so back to square one. I'm going to invest in a better quality gun before the next attempt, and also practice more instead of just jumping in.
Alongside all this, I resprayed my drivers wing mirror. After the disaster with the clearcoat on the wing, I stuck to a rattle-can lacquer for the mirror and it has come out well, so I am calling that a spray painting success, even if it was only the basecoat that actually got sprayed =)) I just went to get a photo but I only finished it last night and after driving it to and from the test centre today it's dirty already. It does look well though, trust me bro!
2.5 weeks away from the Italy trip now. This weekend's plans were to strip and rebuild the interior after I noticed a couple of panel gaps I wasn't happy with. One was one of the screws holding the boomerang had come loose (or not being installed correctly) and meant the drivers' side boomerang wasn't flush. And the other was the locating lug on the console had missed the locating hole when I last fitted it. In addition to rectifying those bits I also gave it all a really good clean and vacuum at the same time.
While the seats were out, I had what I thought was a really good idea - I have fitted a spare footwell storage net behind the passenger seat. I figured this would be perfect for the regulatory high-vis vests and documentation I need to carry with me, but don't anticipate actually needing during the trip. I have yet another spare storage net that will be going in the drivers' footwell, but I need to wait for another set of clips to come now, since I used those ones for this rear bulkhead idea.
In addition to cleaning, fixing misaligned panels and patenting new storage solutions, I replaced the headlight switch since the previous one was flickering and cutting out when you tried to adjust the dash lights. And I moved the steering wheel a couple of splines on the steering column since it was no longer straight when the car was.
Onto more mechanical stuff, I drained the coolant again - I did it in Nov/Dec when I did the thermostat and water pump but only recovered about 5L of old coolant since I couldn't find the block drain at the time. Somehow even with the block drain this time I still only recovered 5L! Has anyone actually checked the full coolant capacity? I am beginning to think this 10.5L quoted is a myth =)) I figure at least if I keep refreshing 5L at a time, eventually all of the old and incorrect grade stuff will be gone.
And last task for this weekend was an oil & filter change.
I'm pretty happy the car is ready for a couple of long Euro road-trips now, it's going in for an aircon re-gas at JWS on April 12th, and other than that I just want to give it another wash and polish (oh, and I'm still waiting for the longer wheel bolts before I can fit the spacers).
Little run out this morning after the oil change to drop the old oil and coolant off at the recycling centre. Temp gauge bang in the middle, and steering wheel straight too 💪
My longer wheel bolts arrived yesterday, so the spacers got fitted. Very happy with how they look, and I took it for a quick spin up the road to check for any noises or vibration. All good! I'm going to keep the shorter wheel bolts in the boot for a few weeks/months so that I could remove them out on the road if any issues cropped up - I'm sure I am overthinking it, but it's the first time I have had spacers on a car.
The second set of storage net clips came yesterday too, so I got the net fitted into the driver's footwell
And then I tackled another impromptu side-quest yesterday - I still have not been able to find a cig lighter dual-USB socket that works in the Z3 cig lighter. No idea what it is, the 12v socket works and the USB adapters work in my other car, but in the Z3 - nada. I had a hard-wired USB outlet left over from the camper conversion, but I just could not find anywhere in the Z3 I wanted to fit it that wouldn't be in the way - Until I had the idea to use the rear switch panel, which on my car only holds the alarm LED tell-tale. I quickly designed and printed a prototype with PLA plastic - I haven't used my printer in ages, the calibration was out and the PLA loaded has been sat gathering dust and moisture for years (literally), so the print quality was garbage, but this was just to check fit. I have ordered some black PETG plastic to eventually print it in which should hold up to summer temperatures like PLA wouldn't.
My original plan was to keep the tell-tale plugged in, but tuck it under the centre console trim, however as Mike pointed out on another thread, my insurer might use that against me if I ever made a claim, so I'm going to try and redesign it with a space to fit the tall-tale.
Version 2 of the prototype looks like it should keep the suits happy! (Orange was the only colour of PETG filament I had to start dialling in the settings while I waited for the black stuff to come. Black has now arrived and is printing as we speak!
100% Do not use the longer bolts without the wheel's spaces or destruction is assured ... as per Lee.
Ouch! Yes, ok, glad I wasn't over-thinking it!!
My new panel is printed and ready to be wired in this weekend! I could/will spend more time dialing in the printer settings, but this is good enough for now and since it's an interference fit into the car (through luck rather than judgement :whistle:) it's going to be dead easy to replace if or when I get a nicer finish.
I got a slightly better spray gun last week and with the warm weather this weekend, I thought I'd have another (third) go at the wing panel on Saturday. It did not go completely trouble-free - the very first coat with the new gun sprayed a load of crap onto the panel, wiping it off with a white spirit-soaked rag took it straight off - and the primer too. I re-primered and on the next attempt the basecoat went on well. It still didn't go straight on with a mirror-finish like it does on YouTube, but hopefully that is the difference between an amateur with an £80 spray gun versus a skilled painter with a £1000+ gun.
I did about 4-5 coats until I had used all the paint I'd mixed up. Left it about an hour to dry while I wired in the USB socket from the previous post, and then I did the clearcoat - this is where the last attempt went hideously wrong. I did a test spray on some cardboard and it looked ok, so I gave it a go! I did about 6 coats of lacquer to give myself a good chance of being able to sand through the inevitable orange peel.
Just like last time, it looked awful when applied (although wasn't dripping off the bottom this time!), but by the time it dried it looked better, albeit not perfect, still a lot of orange peel to work through. I put it in the greenhouse to dry off over the afternoon.
On Sunday afternoon I had a go at wet-sanding it. It went much easier not having to try and remove runs! It's not perfect, I was perhaps too cautious around the edges, and the crease of the arch, but I was pretty chuffed with the middle of the panel! At the end of the day, this panel did have some rust in the lower-left corner. I have treated and filled it, but I am under no illusions that this isn't a fundamentally rusty panel, and I am certain it's only a matter of time before it comes bubbling back through - however this buys me some time and I really wanted to have a go at painting.
I fitted it yesterday afternoon:
Before:
After:
And I fitted my USB panel too :)
I had my aircon re-gassed yesterday. I'd attempted to have this done a few months ago, but the garage identified that the fan was seized and they couldn't refill the system until that was sorted. I opted to replace the fan myself and did that a few weeks ago. With the replacement fitted (but un-tested since there was no gas in the system!) I went to JWS yesterday morning and they re-gassed it fine, the fan works and the blowers were coooold 🥶, Hurah! It's the first time in at least 4-5 years that the aircon has worked in this car. The previous owner didn't even know it had A/C! The idea was to get it working before the Italy trip, however the latest weather forecasts are looking pretty crap, so I doubt we're going to be relying on the A/C anyway. Hopefully it will prove more valuable in June when we take it to Spain!
While I was at JWS I got chatting to a Z4 owner who was in for a new tyre. I mentioned the forum but he didn't seem interested. :confused:
After that I got it home and gave it a wash, clay bar and polish. I had a go at detailing the engine bay too. I'm pretty pleased with how it came out, but I think it's going to be one of those things that I'll need to do a good few times before a) I know what I am doing and b) I've covered the whole engine bay and c) I reckon there are some bits that are just going to need a few goes at before they're clean. I'm also going to look into which rusty bits could be repaired or replaced, for example the front support panel, and various bolts & washers. I need to do something with the power steering cooling loop too. Yuk! Also I kept getting distracted by people walking past and asking why or just generally incredulous that I was cleaning the engine 😅
Very annoyingly, I think rinsing the cleaner away from behind the offside headlight has allowed a few drops of water into the light unit, I'm going to run the headlights for the next few journeys and hopefully burn it off. At least I know the cause and am not worrying about cracked plastic or perished seals.
🇮🇹 Next stop, Imola! 🇮🇹
The Italy trip was a great success (write up here), however two new little gremlins reared their ugly heads:
One was an EML & limp-home mode that happened for the first time with this car since I've had it and only 50 miles into the trip! Restarting cleared it and I was able to continue. It happened another handful of times over the trip. Dipping the clutch and doing a quick restart kept us moving. I can't reproduce the EML on demand, however I think I have established the times it happened was when I was running at slow-speed/idling after running at highway speeds for a while. I didn't have my code reader with me to check the code 'live', however now that I am back home, I was able to read the following codes:
P0141 - 3D Activation, OX-sensor heater after cat, bank 2
P0156 - D8 Signal, OX-sensor after cat, bank 2, no signal
P1510 - D3 Idle-speed control valve, mechanical fault
P0101 - 08 Signal, air-mass flow sensory
I have cleared the codes and am going to see if any come straight back. I'm also going to clean the MAF and ICV. If I need a new O2 sensor I will take it to a garage. The first (and last) time I tried to remove one - on my last Z3, I thought I was either going to break a bone or a tool, or pull the car off the axle stands and crush me - no thanks!
Another thing was while the euro motorways were beautiful and smooth, the local Italian roads where we were staying and shuttling around were horrific for potholes and just generally sh***, and after a few days a number of suspension rattles had developed. I didn't have the space, tools or clothing to investigate beyond looking underneath and check nothing was hanging off, so we drove back as it was and just took it steady on rough roads. I had the wheels off this weekend to have a good look around and found on the passenger side the nut securing the front ARB to the droplink ball-joint had loosened a little, and on the drivers side the nut on the bolt going through the droplink bush had escaped completely! I replaced the missing nut and gave all four a spot of loctite. Other than that I just generally checked that everything else was tight. I didn't find anything loose on the rear suspension, however when I took it for a quick spin afterwards there is still something banging around on the off-side rear that I can hear when I run over a drain grate for example. More investigation required!
There is a bunch more stuff I want to do to the car this year, but other than those niggles, it performed flawlessly and with only 4 weekends before the Spain trip, I don't want to tempt fate by messing about with it. I'll try and resolve the EML and the knocks/rattles, and give it another clean and polish but that will probably be it until mid-June
Total school-boy error.
When I set up my insurance with Hagerty I set my annual mileage at 5,000 miles, thinking it was more than generous for bimbling around the UK over the year.
Working out that just my three road-trips this summer alone are going to total 4,950, not including diversions or excursions, I thought I'd give them a quick call and increase my mileage - oh no I won't, 5,000 is their maximum allowed annual mileage!! (This is my first time having a classic car policy, so I am sure most of you reading this are saying "well duh!" - I had no idea)
So I think I have two choices - one is that I only do these road-trips and the rest of the time lock it up and hide the key until March next year - and also hope we don't get lost on the trips. Or, when I get back from Spain cancel my Hagerty policy and take out a new one elsewhere. (There is a third option which includes some bricks and a dash of inspiration from Ferris Bueller, however I have a hunch that would end badly...)
So I am probably in the market for another classic car insurance policy! =))
A brief trip out on Thursday evening saw the EML/limp-home return, this time no prolonged highway cruising preceding it, meaning my theory was quashed. The view from the Barrel Inn in Bretton was a nice distraction though
(still dirty from Italy though, shhh! 🙈)
Sunday morning I gave the fleet a quick wash, nothing too thorough, and then got it up on axle stands to have a go at the lambda sensor
The only way I could get to the sensor was to wriggle in from the back, my generous curves stopped me from getting to it from the side 🤣. Being completely under the car, on axle stands (set as high as I dared), and on a slightly sloped driveway was a little sketchy. Maybe I was being a nervous nelly, but I didn't fancy cranking on the sensor as hard as I knew I'd need to in that situation, so after a few gentle pulls (you never know!!) I aborted and decided I'd book it in to a garage for the sensor replacement.
Car back on its wheels and JB in the shower getting cleaned up, and I remembered I had a pair of ramps in the back of the garage. I got them for free off FB Marketplace, but they wouldn't work with the 5 series or the front of the Z3 because they are taller than the departure angles allow. But they would work on the Z3 rear axle!
So this evening I thought I'd have another go before I admitted defeat and booked in at the garage...
Got it up on the ramps, blasted around the sensor with the heat gun for a couple of mins and hey presto, I got it off! (Not before checking RealOEM about twenty times and contorting my head and phone around to make sure I was replacing the correct one! 🤣)
I cleared the codes and took it for a quick spin up to Bakewell and back. Checked the codes again when I got back and no sign of it returning. Hopefully that's sorted!
I did/still do want to clean the ICV, but having read about how involved it is to get at, I am inclined to leave that for now and save that for if the P1510 fault code comes back or if I do the M54B30 intake upgrade at a later date
So it seems my relief was short-lived. I had to visit my company's Luton office on Friday and thought it'd be a good test of the new lambda sensor, and with the recent weather in the UK, a chance to have the roof down on the way home.
About 1 minute after getting off the M1 on the way down I got the dreaded EML & limp-mode again. This time with a new addition of it cutting out as I rolled up to a roundabout. A quick restart got me going again but within a few seconds the EML & limp mode were back. Thankfully by this point I was pulling into the office car park. The drive home was a nervous one, but I needn't have worried, it behaved perfectly from door to door.
I checked the codes when I got back and it was the same P0101 and P1510 codes (MAF & ICV) as before. So that forced my hand and on Saturday I went about extracting the ICV for a good clean. I followed the M54B30 tear-down guide since I am getting more familiar with that thread and hope to do the upgrade following it soon.
The ICV felt pretty gummed up, but some carb cleaner and channeling my inner Tom Cruise in Cocktails saw the ICV cleaned up and click-clacking away like a good 'en. In the process of getting to the ICV, I discovered that the rubber lower intake boot was split around the ICV spur, so perhaps I have found the cause of all the problems!
While I waited for the new intake boot to come, I gave the PAS cooler loop a quick coat of paint. It really needs replacing at some point soon, but it's a little less unsightly now. I'd like to do something with the rusty slam panel but am worried that touching it up might make it look worse, especially since the paint around the engine bay is different from the bodywork, right? Any suggestions welcome!
The new intake boot arrived on Sunday afternoon, but I didn't manage to get it fitted before I threw a heat/lack-of-access/tired/back-ache tantrum. I'll try again soon, hopefully when my back is recovered and the temperature is a little more UK-ish
