Why do you push it? Cant you peddle it? That would be quicker?
I would suggest charcoal grey and a light smoked light.. Would look great on silverGazHyde said:I am considering it. It needs a respray so would seem a good time to do it!
I don't want to go as dark as black, but will have to see what looks best at the time.
If you match standard shocks with lowering springs they might not last as long. My shocks were in good nick when I fitted the Eibachs, it only took 2 months the blow the offside front shock. Your standard shocks might last 40,000 miles, they might blow the first time you hit a big bump. With a 30mm drop there is no way of knowing for sure.GazHyde said:Starting to investigate lowering springs/kits for the Zed. Couple of questions...
Eibach do a reasonably priced 30mm lowering kit (springs only) for about £230. Do I need to change the shocks at the same time? Had new front shocks fitted about 10k ago, so would prefer to use them.
The rears I will change as they were on the car when I got it, but again do I go for standard?
I am thinking of putting my car on a diet, my only remaining complaint about the car is that it feels a bit heavy. My plan was to remove the spare wheel, under boot frame, tool kit and maybe think about taking the sound proofing out of the interior and bonnet. My aim is to lose about 150 KG and try to maintain the look of the car. The seat bracket and motor idea sounds like a good plan so I'll follow your thread with interest. Maybe if I should lose some weight, that would shed a few kilos!GazHyde said:Been thinking about weight reduction in general, and sorting out the uncomfortable driving position in the Z3. Obviously the spare wheel is dead weight, so will remove that and the under boot frame.
I've also spent a bit of time looking at the set of ///M seats I'm using currently as bedroom furniture. I think I have formulated a design to reduce the overall weight considerably, lower them about 1.75inch at the rear and tilt them up slightly at the front.
The plan is to replace replace the ludicrously heavy subframe with a lightweight adjustable frame. Will lose most of the weight from removing the two electric motors and the heavy subframe.
Will need to find a local engineering company who can sort some of the work, but it looks like a good plan!
I have a spare seat to practice on before commiting to the chopping the M seats. I was considering after market seats, but can't find any that would look right.
I've done a bit of research and reducing the overall weight is a bit of a problem. Shaving weight from the boot and cabin area is easy but the front end isn't so easy. I was never considering 150KG purely from the centre and rear of the car as it would mess with the C.O.G. Each suspension spring is designed to carry a certain amount of weight. As Zedonist said, it would be detrimental to the cars handling to start changing where this weight is distributed.GazHyde said:Wow, 150kg is quite a target. Work that out to be about 23 stone (2 skinny men, or one big one).
Not sure how much I will shave with the seat bases yet, but will weigh everything as I go. It's either that or lightweight racing seats, but I already have the M seats. Can't find any after market seats which are likely to look ok in the car.
I'm not fat, just a little over cuddly.zedonist said:As a suggestion it would be worth getting the car on corner scales and seeing where your centre of gravity is with you
