E89 Air Filter change
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
When I did my oil and filter change I was going to change the air filter also. However I struggled getting the air filter out. I unscrewed the thee screws at the front as well as.undoing all the clips. However the unit wouldn't come out easily. I gave up as didn't want to do any damage and googled it but didn't find much and what I did find it seemed easy to take the box out.
Am I missing something? It seemed to be held at the bottom, and bottom right is some sort of hinge or placement?
Car is a 2009 E89 2.3
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
Ah so that seems just remove clips and slide up? That's different to some of the videos I've seen. Thanks Colin will have a go
colb
Newport, South Wales,UK
If you want to take the box out undo the top screws and pull the box upwards it's held in at the bottom in a rubber grommet.
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
I only want to change the filter and not take box out if I can help it
