Coming back to my ZedShed thread... It's taken some time but happy to say my Coupe is now running beautifully.
A potted history of what happened in the meantime...
Lee took the car to Munich Legends in May - they dropped the sump and found the oil filter had been clogged by shot debris from the powdercoated rocker cover. So they did a flush & oil change and got it running to the point that the oil light was no longer flickering on - though they did say in their opinion it felt a bit "flat" and down on power. I collected it - got 20 miles down the road toward home before taking it back - it wasn't idling well at all and though it seemed to drive ok, it didn't "feel" right.
They took it in for more tests and found the VANOS had failed which was surprising as it had only been rebuilt about 5000 miles ago. They sent it to Dr Vanos in the US for overhaul who sent it back with a note saying the reason for premature failure had been due to contamination. ML hoped this was due to the shot debris which had since been flushed through but they did an oil sample on the fresh oil to be sure and found swarf in the oil which lead them to inspect the shells which they found were severely worn - to the point where it had scored the crank to the point that it was beyond being reground.
At this point they surmised that the rocker cover had not been cleaned up fully after powdercoating and the debris had formed a paste and made its way through the engine causing damage as it did and aside from crank there was the potential to find bore wear etc. So the choice was to either:
- Rebuild my engine which could be "open cheque book" for cost and in fact might turn out to be beyond salvage, or,
- Source a replacement engine
With their guidance we went the latter route and I was introduced to a chap with an M3 Evo who had removed his engine in readiness to fit a V8. ML did a full analysis of the donor engine, and set about a refresh of this engine - set the valve clearances, replaced the shells, replaced the main seal, fitted the rebuilt VANOS & ancillaries from my old engine, replaced water pump, filled with fresh oil, filter, spark plugs etc.
Also replaced clutch and aircon dryer unit...
They spent a few weeks road testing and setting up then called me in September to say it's ready for collection, so I went over & grabbed it on a Friday afternoon and immediately took it away for the weekend. Initially all seemed well (except I pinged on the airbag light when I adjusted the driver seat) but after a few miles I started to notice an intermittent hesitation at around 3000rpm - couldn't be reproduced at will annoyingly - just every now & then, and would drive beautifully in the rev range either side of the hesitation.
So back to ML last week - they drove the car and couldn't reproduce the fault but it did ping up O2/lambda sensor faults so, belt and braces, changed both - picked up Saturday morning & I've driven a few hundred miles this weekend and no hesitation whatsoever - and indeed it actually feels way more responsive, so I'm pretty sure that it's now 100%.
Which means for the first time since Lee took the car away for it's overhaul in March, I have had the chance to properly put it through it's paces. And oh my god it is delivering on every level! The rebuilt engine feels VERY STRONG and all the work Lee & the ZedShed team put into the suspension is paying dividends too as the handling is CRISP! I did 80 miles across the south downs and loved every yard of it.
It's been an expensive year for this car...
£15k on zedshed/engine
£3.5k on bodywork & ppf
£1k on enhancements (exhaust, rear diffuser etc.)
So basically just shy of £20k it's cost me this year and so far, I've not even run 1000 miles in it!
Was planning to SORN it end of October but I might have to keep it going until end of November and put some more miles on it now it's running so nicely.
Roll on 2022!
