Did a few prep jobs this week, wipers nearly finished, washers checked and prepped (had lost the windscreen washer pipe in amongst the bodywork....so operated the washer, looked where the water was coming from, and there it was)
First back light assembled, holes "modified" a little, and it's now ready to fit.
I will probably leave this now though because at the moment the front end is up on stands. Getting tyres fitted to the wire wheels next week so will be able to fit the front ones, drop the front off the stands and get the back on stands instead, so I can change out the rear springs. Having it up with the back wheels removed will make wiring the back lights easier.
I kept the rear light back plate bulb holders, so hoping to wire directly into the back plates, then the plug can stay operational and the back plates will be able to go back on and cover the old Z3 rear light holes and hide all the wiring....all nice and neat in the boot then.
Intend to try and tidy up all the front wiring (split convoluted tube is a wonderful thing) then fit the front grill chrome surround, and the front grill itself and maybe the bumper and spots. Will also try and finalise the wipers and washers....sounds perfectly feasible but sometimes things just take longer than you think....so fingers crossed.
