Boot light
Antm72
South Yorkshire
Mine has an led bulb in too never been an issue. I'm too of the opinion if its there it should work :whistle:
Alan Slade
Portchester Hampshire
Z3 2 Litre
The previous owner of my car fitted an independent switch for the boot light. I kept this and have an LED bulb and strip lights. Like Blackpool illuminations
When I got my Z there was no bulb in place so I got one of the cree ones off ebay, it works fine and the fact that I have a light means that it has to work even though O never use it at night, I'm just a bit anal like that, it would wind me up if it didn't have a bulb in it :)
Did the same, low power so even if it faults it shouldn't drain the battery plus much brighter
Tracy Dee
Hertfordshire
Cliff fitted it yesterday and it immediately light up no more dangling wires and it's tidy the area up.
But being a scarry cat we decided to leave the bulb out .
Jjim
Mansfield
1.9 Roadster
Glad to hear you got it sorted easily :thumbsup:
Sean d
Lincolnshire
Did you check it with a phone, if it goes off you have nothing to worry about.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
No didn't have time had to use it for work right after fitted.
But at least we know it works if wanted.
Glad your got your light fixed Tracy :p
edwardo
York
Refit it and check if light stays on using mobile phone record method. If it stays on adjust or fix the switch. You can check the switch operation with the lid open by inserting a screwdriver or bar into the aperture.
good think I like your style
