Well back into the Zed Shed with little Fi...
This evening, Rear Suspension... Shocks and Drop links as well as front Drop links and a full oil service.
Interestingly enough the drop links were in such a bad state of repair that they came away very easy. The rear shocks were interesting too.
Old -v- New rear drop links. As can be seen the rear rubber has worn a little.
One of the rear shocks and yes that is fully extended. Just a little issue.
Shocks in place and cover cleaned up. Springs given a wipe down which appear to have been replaced in the past. New drop link visible through the spring.
That is a fully extended shock. Now wonder I had a little lively rear on the Zed. it was only the springs doing the work.
Comparison of the front units. New -v- Old. The perished rubber clearly visible.
Full oil service with filters carried out too this evening.
I can say the drive home was a lovely experience. Much improved.
Work still to carry out is the rear beam bushes and some other items such as the lollipops etc. All good fun when you work with Lee / Trevor and Gary ( Absent this evening )
With thanks for this evening to
@Lee and
@Oldguysrule
And
@Shortie_gal for the pizza.
