Bigger brakes on my Z3 1.9
Brian4
Near Grantham
Z3 3.0i Auto
Honey_Badger
Somerset
1.9 as basic as she comes! Shed that weight!
We must have the same wife then!!!
pgunter
Winchester
2.2i Sport Zedshed Special
I would go to 300. As that’s more than enough for a zed. Brembo discs and EBC yellow stuff pads will give you a great upgrade.
smiffy
Lowestoft
Z3 2.8 pre-facelift in Montreal Blue
Are the calipers the same? 1.9 has solid 12mm discs, vented are 22mm.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Hi
Attached is a file of brake upgrade information. It will hopefully answer many of your questions.
If you want really very large brakes, follow the link right at the bottom of the document. Scary stuff without the brake bias or master cylinder size calculations. Maybe they don't have to worry about modification certification or public safety liability.
pgunter
Winchester
We thought that. Then checked on Realoem and the part numbers for the 286 are the same as the 300 callipers. The width is taken up by the pistons.
The breaker I get the upgrades from does a very good price for all brake parts as a lot have found out. Pm if you want details.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
Great convo guys. Learned a lot. So, I'm assuming you have to get a bigger backing plate if you were to upgrade to 300mm?
Scooblitz
Glasgow, Scotland
No need for larger rear back plate. Current one will fit no problems. Just caliper carrier and 6 pot calipers if you have a 1.9i. All reasonable and available. Carriers will have a "505" cast mark on the inside of the carrier. They look exactly the same , just a touch longer.
Scooblitz
