Been a nice day finishing off the final bits on Andy’s Zed. We had some new dust shields to fit up front and to remake all the brake lines at the rear. Plus some other shinny bits.
First up being the front dust shields. These had totally fallen apart. While everything was off it made sense to fit some fresh Mintex pads and install the braided lines.
Big boy 46mm nut to remove and the bearing just slides off.
Not much left, it left the ABS sensor exposed.
All looking fresh again, just waiting for some fresh paint on the hubs.
Other side got the same treatment
Down the back we installed the roll bar and new drop links. Also found some of the original brackets and bolts in our spares bin.
Next I made the rear brake lines and installed the braided connections. Then it was to bleed everything including the clutch line.
Finally the last piece was the exhaust system. Some fresh flange nuts and a shinny engine brace.
All looking good, would be worth in the coming years to fit new engine mounts and power steering lines, we’re working on a kit at the moment should be ready next year for the lines.
Test drive went perfectly, rude not to get a cheeky shot in front of our local Hawker Hunter.
Now Bella just awaits her MOT in the coming weeks.
