What about a 135i ?
What about a 135i ?
It was done at a friendly independent at just before 100k miles.Was your chain and clutch done at BMW for £1400? and at what mileage?.
when you say later models, do you know what was the year that it was put right?
Isn't the chain at the front on a petrol model? My understanding is that the diesel models had the real issuesWe've just bought a 2005 120i SE for the wife. 80k on the clock
Things weve had in the first 2 months
Chain tensioner is too short: Replaced for £45 and about 2 hours on the spanners with the new uprated parts
Rear ABS rings corrode and fail: had one go already, new Driveshaft and sensor £140 and 4 hours work
uses a bit of oil but i think the CCV is knackered which is a £100 fix and about 5 hours work as the whole inlet has to be removed
My brother in law has a 2007 120d Msport 120k on the clock
he currently has these issues
Clutch and DMF rattle (google it!)
Rear ABS sensor ring gone (Same as ours)
the 118d /120d also have the problems associated with weak diffs and the chain tensioners
loads out there for the money, but i think there are lots more cars our there for 10k that offer better value for money
Different engines...We've just bought a 2005 120i SE for the wife. 80k on the clock
Yup that's why we bought a petrol.Different engines...
Replace chain tensioner on 2007-2012 diesel engines £1250 minimum. hence the concern
Provided its had the work (with proof) they should be fineYup that's why we bought a petrol.
Wouldn't touch a n47 with a bargepole
I think pretty much all the 4 cylinders of this generation are prone to mishaps
