Announcement ZRoadster.org Car Stickers available
Status
Not open for further replies.
As above I have just received delivery of a new batch. Sadly prices have to go up 50p per sticker to £3.00 + P&P due to increased production costs.
Fitting Instructions :
The sticker is made of cut vinyl, so each letter is an individual sticker in itself. This is supplied between a ‘sandwich’ of masking tape and stiff paper backing.
  1. Clean the area of window/surface you are sticking to thoroughly.
  2. Carefully peel off the backing card making sure that the vinyl does not lift off the masking tape (watch out for the full stop!). It’s reasonably easy enough to see through the masking tape!
  3. Tack the sticker in place using the top corners trying not to let the sticker touch the surface. You can re-position carefully if needed by lifting the corners.
  4. Use a cloth or microfibre to ensure that the sticker is firmly fixed to the screen by pressing through the masking tape.
  5. You can now carefully peel back the masking tape, and again watch for any of the vinyl lifting as you do so! If it does stop, and then press down again firmly with a cloth.
  6. Once the sticker is applied, leave it a couple of days before applying any pressure on it. The vinyl is soft, but it will harden up relatively quickly. Ideally avoid too much direct contact on the sticker when cleaning the area it's attached too.
The vinyl stickers have lasted over 2 years on my current Z3, and are still in good shape!
Have I paid enough post or should it be £3
Thanks Simon :thumbsup:
Standard "letter" is correct. Just enough to cover an envelope & first class stamp! Not really sure why it has 2 parcel options, I don't really want to take it down the post office, when there is a post box a short walk down the road...
Shouldn't have spoken so soon, just got an order from our Canadian correspondent! That'll be me off down the post office then...:facepalm: =))
Bozzy
Long Eaton.
Hi Gaz just tried to place an order for a few stickers,got to the 'place order' part and when i click on it nothing happens,can you advise on what i may be doing wrong please.
Not sure, have you got to the Shopping Cart, or past this bit?
My order figured £3.50 @GazHyde so you should just stick that on the envelope and shouldn't have to go to the PO!! JIM
I was only joking Jim, the post office is really easy to get to where I live ;)
That's just plain old mean Frankie, like it.:ymdevil:=))
Do you have any other designs? Maybe something a little more minimalistic?
I had some ideas, just haven't got very far with it yet :)
  • Like
Reactions: Lee
Gail
Nuneaton
Z4 20i MSport
I have just ordered mine....if it saves you a job @GazHyde you could bring it to the meet next Sunday.
I'll put it in the post with the other 2 orders tonight, as I'm still not sure I'll make it next weekend. I'll have a new clutch in time, but I've spent all my cruise money up in the process!
Status
