Thanks mate. Shirl helped me do the sunstrip on the screen as we had to measure it carefully to keep the top and bottom parallel to each other to make it "flat" across the screen. It will also carry the web address for our villa and once that is fitted I will be able to trim some off the lower edge. The one on the roll bar came from an off cut of the sunstrip with the Zorg applied and trimmed to suit and hey presto.
