Z3M number plate bulb replacement
BillH
Hi - haven't attempted changing the bulb yet but just need advice on how to get at it without scratching/ breaking the housing or bumper. Oh, and is it the 501 bulb?
Thanks for any help offered
Bill
Thin plastic trim tool is best and it just pulls up and off, easy enough to just get a finger nail under each end and gently pull. Its not overly tight.
Pretty sure its a BA15s, its not the same as non M Z3s
Gremlin
Salisbury
Z3 1.9
Like the man said the whole light just pulls out it is sort of spring loaded so may need to push slightly to one side or other and pull it out at same time. I changed mine for L.E.D brighter light less power.
Ditto, fitted a super bright LED from Horizon LED
BillH
Aha, thanks, that's what I want to do so thanks Niall and Gremlin - I'll get on the Horizon website. 👍👍👍
One is offset pins the other is parallel pins cant remember which it was now, you need to check what's in there, I went for the 50w clear
BillH
Great, thanks again Niall - you're, once again, putting me on the right path 😛
