Here's the Problem:
Today I rolled the passenger side window down (luckily not all the way). When I tried to roll it back up it moved upwards for like an inch or so and then slowly moved back DOWN again with the motor not being able to lift the glass up under it's own power.
I grabbed the window and gently pulled it back up while holding down the switch. When I later tried this with the engine running I had the same problem. Both times it did not make any cracking sounds.
Even before this happened the passenger side window was slow to operate, probably through lack of use - the driver side window works perfectly fine.
Does the window regulator just need some grease or is the electric motor just about to fail?
Thanks in advance
Thanks in advance
