Z3 1.9 Project - Parts Manual
Sean Hilton
Saffron Waldon
1.9 Roadster
Morning all,
From a cold a sleety North Essex, compared to last week that is when almost tropical, well anyway managed to clear out garage, and start on Z, (Head gasket) well anyways removed waterpump, intake manifold , and rail, noticed a lot of smaller rubber hoses are showing signs of wear so will replace.
assuming weather better this week, will remove exhaust manifold, and go for head, main reason for thread tho, any body got a link to a parts manual covering the M44 engine?
any advice would be appreciated
Sean Hilton
Saffron Waldon
1.9 Roadster
Hi Jonco
Yeah thanks for that, have seen that before, don't know if you have ever done a head gasket on the 1.9 but getting the inlet side off was a pain,.
Hoping to do exhaust side this week then, then head, coolant was pressurising , initially though was air block, but wasn't, have got a spare head, so if the one fitted is shot, can stick that one on
jonco
Chester
'98 1.9 Auto
...... don't know if you have ever done a head gasket on the 1.9 ...
Fortunately not had to go that far and don't want that experience - have done rocker cover seal, cooling pump and injector change and hoses so I can envisage difficulties with the rest. If you are doing hoses may be worth looking at plastic hose block connectors while you have it apart. I didn't do mine as access is a pain with most of the kit in place. Good Luck.
Mazza
Bognor Regis
Hi Sean, if you need any Torque info, there is a list on the ‘Z3 Roadster and Coupe ‘ section of the forum ( one of the sheets is M44 specific)
Also, I do have the Bentleys Z3 service manual if you need any specific info copied
Sean Hilton
Saffron Waldon
1.9 Roadster
Evening Mazza,
thanks very much advice and offer, im currently off at mo due to coronavirus so have the perfect opportunity to crack on, assuming weather stays fine, currently sourcing 5/16 van hoses, what a faff lol
Sean Hilton
Saffron Waldon
1.9 Roadster
Sean Hilton
Saffron Waldon
1.9 Roadster
hi Jonco,
yes, currently looking at the hoses to rail, think they have all seen better days, so its going to have to be a swift purchase of 5/16 vac hose me thinks
Sean Hilton
Saffron Waldon
1.9 Roadster
jonco
Chester
'98 1.9 Auto
hi Jonco,
Sorry thought you meant cooling hoses and I meant parts 1&2 on first pic and 8&9 on second upload_2020-3-29_19-49-15.png
Done all this a year or so ago any questions just ask try help out if I can .
Had to replace the head on the mrs zed as it was suffering from terminal issues.
Sean Hilton
Saffron Waldon
1.9 Roadster
wicked,
ta Stevo, yeah its a pain, inlet side off, so am nearly at stage to pull off head,
handsomejackuk
Australian Zeds
t
Hi,
query here just doing rocker gasket on my 1.9 m44.
I noticed there is quite a large step between the timing case cover, and the cylinder head so that when the rocker cover fits the timing case cover is sitting about 1mm higher than the cylinder head... could it be that maybe my cylinder head has at some stage been skimmed, and should it be that maybe 1mm should have been taken off the top of timing case cover, to bring both the surfaces to the same level ? or will it be ok to just use hylomar or equivalent rtv type sealant to fill the gap... ?
my other thought was to maybe loosen my top timing case cover and see if it will move done a little bit to reduce the step between the two surfaces...
does this make sense ?
heres a youtube showing what i mean skip to 10:12 seconds to see the top timing case cover.
View: https://youtu.be/ykOlgpnYMdg?t=612
