SOLD Z3 1.9 Manual - 148k - £750
McSwerve
BMW Z3 1.9 M44 Manual
First registered 1st March 1999
Mileage circa 148k
MOT Until 1 August 2019 (Service History includes all the old MOT's)
I've owned the car since April 2016 in that time I've done, or had done the following work:
Suspension Overhaul
  • New Rear Spring and Shocks
  • New Front Spring and Shocks
  • Z3M Rear ARB
  • Rear Diff Mount Bush - Pollybush
  • Lollypop Bushes - Pollybush
  • Front Lower Control Arm
Brake System
  • New Rear Callipers
  • Rear Discs & Pads
  • Front Pads
Body
  • New Aerial Gromit
  • Replacement Soft Top - Soft Tops Croydon £350
  • Boot light gasket (to be fitted)
Exhaust / Cooling System
  • New Exhaust - Aftermarket
  • New Cat - Aftermarket
  • New Thermostat and coolant chang
Service History
  • 9,800 Miles - Bridgegate BMW Derby
  • 17,511 Miles - Response Autos
  • 26,541 Miles - Response Autos
  • 34,779 Miles - Glos BMW Specialists
  • 44,733 Miles - Glos BMW Specialists
  • 57,028 Miles - Dick Lovett Bristol
  • 65,500 Miles - Wheelbase BMW Specialist
  • 78,128 Miles - Wheelbase BMW Specialist
  • 85,649 Miles - Wheelbase BMW Specialist
  • 87,989 Miles - Chesham Car and Van Sales
  • 97,621 Miles - C G Motors Chesham
  • 109,210 Miles - C G Motors Chesham
  • 120,116 Miles - Owner Serviced
  • 131,974 Miles - Owner Serviced
  • 144, 152 Miles - Owner Serviced
Bad Points
  • Due to some thieving so and so stealing my coat (including keys) from the pub, I only have one key, and that is a Service key (£40 from BMW, a remote key from BMW was about £250 which didn't make much sense on a cheap car.
  • A service key doesn't open the boot or lock the glove box, therefore the 'key' for the boot is 'improvised.
  • The electrics in the passenger seat don't currently work.
  • There is some bubbling on the bolt on / off body panels, which, as we all know
    is a common Z3 issue.
Summary
It's been a reliable, nippy and fun little car for running around in the summer, I've certainly enjoyed owning it.
Priced realistically, as you can get really good ones for very little.
Probably worth more in bits but hopefully a good starter Zed for someone. I'd happily drive it to the south of France tomorrow!
mrscalex
Swindon & Swansea
I don’t think you put whereabouts you are?
If it helps you or a prospective owner I might be able to advise on getting a proper key cut and the transponder coded for a much more modest sum than the £200 plus from BMW.
I can get keys made up normally no problem. But working out how to uplift a service key to a main key might need some figuring out. Transponder coding certainly no issue.
Wouldn’t normally offer but a proper key might make the difference between keeping the car going with a new owner and meeting a sadder fate..
mrscalex
Swindon & Swansea
Did some checking and the difference between a valet key and master key is actually very minor from what I can see. Subject to confirmation with the locksmith I use:
  • A master key can be reverse engineered from the valet key and supplied and cut for about £20. That's the bit I need to check but from what I can tell it's simple enough. It can be done off a photo, the key doesn't need to be sent away and is actually a better way of having any key done than having it trace cut. In this instance the valet key can't be trace cut as it is missing cuts that are responsible for opening the boot
  • A PCB is then required for the new master key. Donor keys from ebay for £5-£10
  • The transponder can then either be moved from the valet key - not sure how as I've never examined one (I think I have one somewhere if I can find it) but it got in there so it must be able to come back out. Or I can create a new one if the EWS is removed and sent to me for a small charge to cover costs. £20 with return special delivery and supply of transponder.
Hope this helps you or a prospective owner :) It seems like a cheap car to me with all those bits for £750 and a proper key would be nice for it :)
Send me a PM if you want. No worries otherwise - I wanted to find this info out for myself anyway.
McSwerve
Thanks for that, good info.
When the coat / key was stolen I did a quick bit of research but couldn't find a non main dealer solution.
I had to get is sorted quite quick, as the car was stuck in a multi-storey car park ££, so the local dealer got one from Germany in a couple of days.
Good point regarding location, I'm in Bedfordshire.
Something else I missed the tyres are all pretty new Kumho's which went on about 3k ago.
mrscalex
Swindon & Swansea
If someone is on a low budget for a Z3 then this looks a bargain to me. All those new bits should mean there is a lot less renewal than most Z3s need.
Craig Machin
:thumbsup:Looks like a very reasonable price to me. Good luck with your sale
jony9
Thank you so much for the interior pictures I was hoping for the beige interior with roll hoops. Sorry to mess you about. Good luck with the sale
Dino D
Kent
2.8 Manual
This is so cheap hoops would actually add about 50% to the price of this :whistle:
An eBay auction should be interesting for this car, you may get around the asking price after fees.
jony9
I know but I was after hoops for my car in beige if they were beige and not black I would have bought the car to strip
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Don't think I've ever seen beige hoops I thought all hoops are black
Can they not be coloured like any other interior bits?
McSwerve
It had hoops and the net wind deflector thingy that I sold separately. Thus being able to offer it at such a bargain price!!
McSwerve
It’s time I pulled my finger out and reduce the fleet.
The mighty Z has a fresh MOT and I’ve just replaced the rad, thermostat and water pump.
Any takers before I risk eBay / Pistonheads / Autotrader?
