Paolo sala
- Joined
- Jan 31, 2018
- Points
- 1
Hi,
I am restoring a Z1 and I have issue with the driver window.
The door works perfectly and when open it the window follow it and goes inside. When I close the door the windows close but not completely (like in the wheeler dealer episode, leave 4 cm. Gap with the soft top).
And the windows itself doesn’t work with the internal switch (if I want to open the window I need to open the door).
Tried to swap the switch and it works, swooped the ecu but no luck. What could be? The motor works, could be a microswitch? How to find which one? Thanks in advance
