Dave Bacharach
- Joined
- Oct 13, 2017
- Points
- 16
Reservoir is full, I can hear the motor humming when I activate it, but no squirts. Clogged line? And if so, how would I unclog it?
I’m sure that they aren’t that expensive form the dealersYou can buy w/washer non-return valves on eBay for little money.
Thanks Silver. Question: How does one get the pump out. Brute force? I emptied the reservoir and can see the small intake end, but I can't see how to get the pump out without simply prying it. Pumps here are also pretty cheap on ebay, so if I can get it out, I can clean it up and then check it with a glass of water.I had exactly this problem and mine was caused by sludge and slime clogging the filter in the washer reservoir. The fix was to remove the reservoir and pump and give it all a good clean. An easy and free repair
Yes, on mine, a 2002 the pump just pulled out. The filter is attached to the pump....Question: How does one get the pump out. Brute force? ...
