Rebody What GRP filler?
Pond
Spaldingski, Lincs
Z3 project and E89 Z4
I am thinking about filler for the body. Hopefully just for the imperfections in the mouldings, but who knows?
Is 'gelcoat filler' the way to go, or for minor filling and sanding should I use plastic 'bumper' type filler?
I have some U-pol plastic X (6) but not sure if it is the right stuff to use!
Duncodin
Pontrhydyrun
Z3 M44
Isopon P40 is a kind of gel with glass fibres mixed into it. It can be used to bridge holes gaps.
Isopon P38 is a paste used for filling grooves, dents but not holes.
I use P40 to bridge the hole, fill most of it to within a few mm of the surface and then skim with P38.
I mentioned Isopon because then there's no doubt about what I mean. In fact there's alternatives and halfords have a uPol fibre filler in a nice big tub much cheaper than isopon p40 and does the exact.same job.
Duncodin
Pontrhydyrun
Z3 M44
If you're bridging a hole in grp don't forget to roughen up the edges to give the new filler something to grab on to.
Pond
Spaldingski, Lincs
Is this the one you were thinking of?
Duncodin
Pontrhydyrun
Z3 M44
That looks like the smooth paste. Use that on the surface.
This is the fibre reinforced gap filler
Duncodin
Pontrhydyrun
Z3 M44
I would add that I think the isopon might feel a bit thicker. Maybe more fibre in it. But I bought this big uPol 900ml tub from halfords so this is what I'm using. It feels softer than isopon so might sag on bigger holes. But then I'd say we should be doing big holes with proper mat and gel anyway.
Pond
Spaldingski, Lincs
Halfords don't do that one anymore (at least it's not on their website).
I am only talking of filler for imperfections and small bits, not holes. Any holes, hopefully none (!), will be addressed with glass (once I work out how to do it!)
Duncodin
Pontrhydyrun
Z3 M44
Small imperfections then a paste like the one you showed.
But really tiny marks such as scratches and pin hole sized things then a high fill primer. Couple of coats with a rub between each one.
